Lifter and Rocker questions for L92 heads
I am buying a set of L92's with Manley 1426 spring package. These springs have 140lb seat and 385lb op[en pressure at .65 lift.
Are the stock LS2 lifters Ok with these spring pressures?
Are the stock L92 rocker arms OK with these spring pressures too?
These will be going on a A6 vette with stock bottom end.
Originally Posted by Cop Car
so i take it LS1 rockers work fine with the L92 heads? are the L92 rockers 1.7 ratio also?
Only the exhasut rockers will work with those heads, the intake has an offset. The lifters will work just fine. I am going with the LS7's just to be safe. Also, they are 1.7 ratio.
Originally Posted by DoesSpeedTurnUon
Right now, you're only choice is L92 rockers i believe. And yes, i think the lifters are ok too.
oh yeah, and what about the "Engine Valve Adjusting Support" buy L92 specific or can the LS1 piece be used
Actually, I just threw my LS7 rockers on my new L92 heads to check. The offset is fine.....the problem I see is that the rockers look to be a bit too long. They actually overshoot the valvestem tip. Guess that was some money wasted on bad advice.
Here's a really bad picture (sorry, I can't get the camera to focus that close to something....don't get much for $500 these days) of what I'm talking about:
1.8 vs. 1.7
He asked why the LS7 rockers wouldn't work....your response is 1.8 vs. 1.7?
How about vave angle difference of 3 degrees making for a longer fulcrum to tip length?
