Oil Pressure Question?
Old 02-04-2007, 11:31 PM
PunkNPonys's Avatar
Default Oil Pressure Question?
Well i was driving the car today and noticed that my oil pressure was sitting lower then usual. At idle the car is right around 20psi and then cruising at a normal speed it sits right about 30psi and then when i get into the throttle it shoots to 40psi. Is this something to be worried about? I thought they usally sit right around 40psi normally and then shoot up above that at WOT? What do you guys think it could be? I replaced the sending unit not to long ago so i dont think that is the problem.
Old 02-05-2007, 01:39 PM
PunkNPonys's Avatar
Anyone?
Old 02-05-2007, 02:48 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
A general rule of thumb is 10psi per 1000 rpm. So 20 psi should not be of concern at idle. Just make sure you have sufficient rpm at redline...
Old 02-05-2007, 10:35 PM
PunkNPonys's Avatar
Do you think running 5w-30 vs 10w-30 would cause lower oil pressure?
Old 02-06-2007, 11:38 AM
silverbandit0996's Avatar
it would be lower at operating temp. but the same at start up from what i understand. mine sits at like 50 psi at idle and at wot it is 80+. so to me it seems kinda low.
Old 02-06-2007, 07:20 PM
chewy99ws6's Avatar
mine runs at about 60+ on startup, 25 at operating temp., and about 40-60 on wide open
Old 02-06-2007, 10:08 PM
Tiger2o69's Avatar
How much oil pressure did you use to have? How long ago since you did the cam? Change oil pumpes? Change timing chain?
I would say 40 under wot is low. You can say 10psi for ever 1k rpms but on our cars its usually more than that.
Old 02-06-2007, 11:27 PM
Blk97WS6's Avatar
I agree. 40psi is to low for WOT runs. sounds like your oil pump my be starting to go out on you. is it the original or aftermarket?
