popping sound?
Old 02-06-2007, 06:55 PM
MIDNITE Z's Avatar
Default popping sound?
Anyone have any idea what the popping/ticking noise is? Coming from the rear of the car near the exhaust (under trunk). A few weeks ago I had the exhaust leaks welded.
http://smg.photobucket.com/albums/v3...Picture085.flv
http://smg.photobucket.com/albums/v3...Picture087.flv
Old 02-06-2007, 07:45 PM
josepy121380's Avatar
when the last time you changed your spark plugs? my car did that. changed plugs. runs like a top.
Old 02-06-2007, 08:23 PM
MIDNITE Z's Avatar
Changed them in June 2004......Could it be my 02 sims going bad
Old 02-06-2007, 08:46 PM
when i put my plugs in i had to change then 3 months later. then i bought the good ones. see if you can get someone to see if your car is throwing any codes. i think it could be also that your a bears fan. that could be the real problem.
Old 02-06-2007, 09:21 PM
aggie-chase's Avatar
You sure it isn't just unburned fuel detonating in the exhaust? Mine does that occasionally...especially when it's cold.
Old 02-07-2007, 01:31 AM
MIDNITE Z's Avatar
Old 02-07-2007, 05:06 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Same thing here.
Old 02-07-2007, 08:17 AM
jimmypop13's Avatar
all i'm hearing is a ticking sound. I thought maybe it was an exhaust leak but you said they were all sealed up. What does it sound like when you rev it?
Old 02-07-2007, 09:05 AM
skifast87's Avatar
Im with you buddy
Old 02-07-2007, 09:12 AM
FU_I_AM_UltraZ's Avatar
check the plugs. these cars do that stock trim on cold starts b/c motors are tuned to run rich to heat up faster. if you did a header swap, you could have cracked a plug and see a flashing SES light or just that you're A/F ratio is messed up.
Old 02-07-2007, 05:50 PM
MIDNITE Z's Avatar
It would pop when I rev it. It only happens when I drive the car for awhile. The next day it is fine until the car gets hot.
Old 02-08-2007, 09:07 AM
so it pops after it gets warmed up?
Old 02-08-2007, 09:46 PM
MIDNITE Z's Avatar
Yes!!
Old 02-09-2007, 12:48 AM
That's what she said...
TheBlurLS1's Avatar
You still have cats on the car? Maybe it's a piece of chipped off catalyst flopping around in there?
Old 02-09-2007, 08:53 AM
that would cause some rattling
Old 02-09-2007, 03:41 PM
MIDNITE Z's Avatar
No Cats
Old 02-09-2007, 05:21 PM
MIDNITE Z's Avatar
Well I scanned it and nothing showed up....However when the car was idling it was making weird noises(sounded like there was a cam in it) and the car jumped to 2000 rpm...WTF
Old 03-16-2007, 01:40 AM
MIDNITE Z's Avatar
Well...a few weeks ago I lost a spark plug.....after replacing it the ticking sound is gone
Old 03-16-2007, 11:36 AM
skifast87's Avatar
there we go
