Anyone know torque specs for arp head studs?
Old 02-08-2007, 10:00 PM
SPRAYED 01's Avatar
Default Anyone know torque specs for arp head studs?
Im putting my heads back on this weekend. Its been a while and i dont remember the sequence and torque specs. They are arp 12 point studs,also the intake specs. Im using cometic .051 gaskets if that matters and a fast intake.
Thanks alot.
Alex
Old 02-09-2007, 12:02 AM
thehammer69's Avatar
Thanks alot.
Alex
Using ARP's moly assembly lube...70ft/lbs on big studs and 23ft/lbs on small studs.
Hammer
Old 02-09-2007, 12:09 AM
Mean Green z28's Avatar
I like to go in steps, usually 2 steps and then the final ... and then the little ones
Old 02-09-2007, 06:25 AM
brad8266's Avatar
25lbs on the 5 top ones, 70 on the larger ones. This of course is when you use ARP moly lube too.
http://www.arp-bolts.com/Catalog/Catalog.html
Scroll down and click on torque specs.
Old 02-09-2007, 07:40 AM
SPRAYED 01's Avatar
Does anyone know the sequence or is it the same as stock?
Old 02-09-2007, 07:46 AM
brad8266's Avatar
same as stock, see attached picture.
Attached Thumbnails Anyone know torque specs for arp head studs?-torquebolts.jpg
Old 02-09-2007, 07:48 AM
1baddls1's Avatar
i dont want to hijack your thread bro but can someone shed some light on the ARP Moly Lube???
is it neccessary?
Old 02-09-2007, 07:57 AM
brad8266's Avatar
is it neccessary?
It is highy recommended because that is what ARP uses to get their torque specs. If you use it and tighten a bolt to 70lbs and take another bolt and with no lube on it and tighten it to 70lbs, the 2 bolts will have different clamping pressures due to the friction differences in the 2 bolts. Using moly lube is a way of getting consistent clamping force out of a bolt for a given torque value.
Old 02-09-2007, 09:53 AM
SPRAYED 01's Avatar
Great thanks alot guys. Hopefully my other head gasket will come in and ill have this thing running this weekend
Old 02-09-2007, 10:47 AM
Brad, I realize that the small bolts themselves generically allow for 25lbs...but the spec in this specific application is 23 ft/lbs. It probably has to do with stress on the aluminum threads in the block.
Hammer
Old 02-09-2007, 11:57 AM
brad8266's Avatar
Hammer
lol, 22, 23, 25 whatever, its really doesnt matter. Where did you get 23 from anyway, cite a reference please. if goiong up to 25 from 23 breaks threads, your block is a POS and fucked up in the first place.
Old 02-09-2007, 01:03 PM
jfrc2000's Avatar
use the lube, do not use oil- torque is too high
Old 02-09-2007, 05:49 PM
JPH
JPH's Avatar
Thanks alot.
Alex
well since you are using cometics, i would do 85ft. lbs on the 11mm studs, and 27ft. lbs on 8mm studs. i do on my engines. cometics have a reputation of not sealing, because of not enough clamping force. go in three steps also when torqing studs, like the others have said.
Old 02-09-2007, 06:45 PM
SPRAYED 01's Avatar
Anyone else for torqueing more do to the cometics.
Old 02-09-2007, 06:53 PM
vettenuts's Avatar
Only if you want to risk it. The bolts are stretched to a percentage of material yield. The ARP's have limited ductility, exceed yield and you may break it. I would consult ARP before altering their torque specifications.
Old 02-09-2007, 06:54 PM
vettenuts's Avatar
I was also given 23 lb-ft by ARP tech support.
Old 02-09-2007, 10:01 PM
Quick Double Nickel's Avatar
Is the moly lube just used between the nut and washer or washer and head, or on the actual threads? What about ARP head bolts? Is it the same 70/25 numbers and moly lube between the head of the bolt and cylinder head?
Old 02-09-2007, 10:41 PM
brad8266's Avatar
On the stud threads, washer face, and nut threads.
With bolts it goes on the bolt threads and face of the bolt head where it contacts the head.
Torque values are in the link that i posted above.
Old 02-09-2007, 10:44 PM
brad8266's Avatar
So would you listen to the guy on the phone or the published and printed tech data sheets that they put out?
Quick Reply: Anyone know torque specs for arp head studs?
