what are good heads for FI?
Old 02-16-2007, 08:24 PM
C Murda's Avatar
Default what are good heads for FI?
ok well ive come down to deciding in staying with the standard ls1,2,6 setup with 15* heads. what are the best heads i can get to use for high boost? i dont want to go over to an iron block i will be using ARP studs and dont want to have a problem with my heads lifting under boost. what can i do and what heads should i choose? a lot of people seem to use AFRs is that my best choice?
Old 02-16-2007, 08:44 PM
WAHUSKER's Avatar
AFR 225s are great if you have the money. I bought some 6L heads & had them reworked. I have around $1500 total invested in them. I have an iron block with Cometic gaskets....no problems after 1 year. Get heads with big chambers to keep the CR low.
Old 02-16-2007, 08:52 PM
Super Moderator
Reckless's Avatar
Heads are not nearly as critical with FI....we have made 1700+hp with cathedral port heads. Don't getme wrong, a good head is a benefit, but not as crucial compared to a normally aspirated application.
Old 02-16-2007, 10:55 PM
BIG BAD BLACKSS's Avatar
So other then the deck thickness, the rest of the head isnt all that important? Im trying to decide on heads now, considered LQ9s and darts, maybe AFRs but i dont wanna drop that coin honestly. Especially if its really not that important.
Old 02-17-2007, 02:42 AM
6techniques's Avatar
Coming from W2W, I'd take that to the bank!
Old 02-17-2007, 08:00 AM
EPP
EPP's Avatar
We use Patriot Performance LQ9 heads on a lot of our builds. Stage 2 for smaller cube engines, Stage three for the larger cube engines.
http://www.exoticperformanceplus.com....html?item=409
http://www.exoticperformanceplus.com....html?item=649 Bob
Old 02-17-2007, 08:44 AM
98redorangeta's Avatar
Id go to the bank and take that to W2W
Old 02-17-2007, 10:44 AM
NA$TY-TA's Avatar
Im a Huge fan of 6.0L heads.... running them myself with only 2.02,1.57 valves....
Old 02-17-2007, 11:50 AM
C Murda's Avatar
ya i know flow numbers dont matter too much with FI but the only reaswon i mentioned AFr was cause of their thicker deck. i am ok with spending the money for AFRs just wanted to know what is the best so i dont have to worry too much about lifting the heads...
Old 02-17-2007, 12:54 PM
well there are plenty of guys running single digits on production heads without too many problems...but if you have the money burning a hole in your pocket, get the AFR's if thats what you really want because in the end its your decision to make.
Old 02-17-2007, 01:33 PM
cablebandit's Avatar
i got some refurbed prc Darts cause they were cheap...otherwise i'd be using stock 317 with good springs prob.
Old 02-17-2007, 02:19 PM
CALL911's Avatar
AFR 225's will to well. Personally I like the TFS heads. After seeing a buddies flow numbers off of his LE ported TFS heads, I would highly reccomend them, especially for the price.
Quick Reply: what are good heads for FI?
