Does the stock clutch grip harder after the drill mod?
Just wanna know if I can keep spinning the tires in 2nd from first, as of right now I can't......but that's NOT powershifting.
Originally Posted by calhoon
Shifting with the tires spinning will def. take out your synchros. The drill mod only affects apply rate of the hydraulics NOT ultimate clamp load( thats the clutch's job)
So its bad to shift gears during a burnout?
You would have to know how a synchronizer works to see the problem.The synchros job is to match speed of the engine/trans/vehicle. The vehicle speed with spinning tires is way below what it would be with traction. Matching that differential in speed is grossly multiplied under those conditions and wears synchronizers fast.
