Oil Psi
Old 02-22-2007, 01:22 AM
Hawk_479's Avatar
Default Oil Psi
Ok I figured I would start here with the questions, I was at the track tonight waiting in line and I noticed that at idle my oil pressure guage was going back and forth anywhere from like 30-40 psi without me touching the gas or anything, and Ive never even seen it go below 40. (BTW I have a 2000 firehawk, only mods are cat back and lid so its pretty much stock). I was talking to a guy there that builds engine but not specially ls1's so he was just making educated guesses, and he was thinking that it would be the electronic sending unit rather than anything else.
So let the opinions come, I need as much input as possible!!
Old 02-22-2007, 11:27 AM
bjamick's Avatar
You would pro get more replys over at the external or internal threads.. But i would say its prob just normal when your sitting there.
Old 02-22-2007, 12:57 PM
Hawk_479's Avatar
No def not normal, this is my second trans am and neither one has ever done it, plus I've never seen another fbody let alone another car have varying oil pressure at idle
Old 02-22-2007, 04:06 PM
carman53's Avatar
I have a '98 Z vert A4 with 110K on the clock. It has done the same thing sporadically since about 88K miles. Mine twitches with a small left right movement. Does not do it all the time, just once in a while. I am HOPING it's the sensor.
Old 02-22-2007, 04:25 PM
TheLS1Kid's Avatar
When the car heats up the oil breaks down and gets thinner, which is why the pressure goes down a little. Thats pretty normal for idle. As long as the pressure goes up along with the rpm's, your fine.
Old 02-22-2007, 10:24 PM
1baddls1's Avatar
10 psi for every 1000 rpms minimum is the "rule of thumb"
mine does the same - & on hot summer days will drop down to 20 @ idle
persoinally i switched from Mobil 1 & AUTOMATICALLY saw average 5-10 PSI more... M1 runs thinner then other companies
i use Castrol now & will be switching to Redline
Old 02-23-2007, 01:50 PM
Hawk_479's Avatar
Yea thats what I been using is castrol, but this is my second trans am and neither has ever gone below 40 no matter how hot or hard I pushed it. But I just changed the oil the other week, and thats when it started happening. Does anyone know where the oil pressure sensor is located? Because if its near the filter that explains it, because I really had to beat the hell out of mine to get it off.
Old 02-23-2007, 02:22 PM
TheLS1Kid's Avatar
The filter should come off fairly easy. Why did you have to beat the hell outta it?
Old 02-23-2007, 02:37 PM
Hawk_479's Avatar
The guy who had the car before me must have torqued it down way to much, and i just couldnt get it off, even had a few other ppl try it.
Old 02-23-2007, 03:05 PM
High on diesel fumes
thunder550's Avatar
Oil pressure sender is behind the intake manifold on the driver's side of the block.
Old 02-23-2007, 03:28 PM
TheLS1Kid's Avatar
correct.
The intake manifold has to come off to get to it though. I doubt there is anyone on here who has done it without taking the intake off while the engine is in the car. If someone has, please tell us how and what you had to do to get the the sending unit. I'd like to know for future reference. Thanks.
Old 02-23-2007, 03:34 PM
thunder550's Avatar
I don't think it would be possible with the manifold still on. I have tons more room in my truck and I can't even get to mine with the manifold installed.
Old 02-23-2007, 03:35 PM
TheLS1Kid's Avatar
wow, i always thought it would be possible if the motor wasn't so far under the cowl.
Old 02-23-2007, 03:39 PM
thunder550's Avatar
Well, the truck manifold is a lot taller than the car manifold, so that might be part of it.
Old 02-23-2007, 03:42 PM
TheLS1Kid's Avatar
Oh ok, i was assuming you had an LS1 or LS6 manifold.
