Its no problem to run GM 6 liter gaskets with stock LS6 heads on LS6 motor right?
Old 02-22-2007, 12:50 PM
Chicago Crew UnderBoss's Avatar
Default Its no problem to run GM 6 liter gaskets with stock LS6 heads on LS6 motor right?
I heard some guys on a stock cubed LS1/6 motor will put on 6 liter GM OEM gaskets to knock down the compression a tad.
How much will this knock down compression on at stock 10:5 comp. LS6 motor and are there any problems that can surface by doing this?
Old 02-22-2007, 02:29 PM
kp
kp's Avatar
If the gaskets are .50 thick for example you are looking at maybe .05:1 difference between a 3.9 and 4" gasket bore. Hardly significant..
Old 02-22-2007, 03:25 PM
iamsickofitall's Avatar
i agree - maybe .05
i THINK the 6.0L MLS gaskets are ~.08 or so thicker than stock graphite - but i couldn't justify going from 5.7L MLS gaskets to 6.0's
Old 02-22-2007, 05:42 PM
eb02z06's Avatar
Bro-this is eb02z06 from the CF forum- 6.0 and 5.7 gaskets are the same thickness-you would need to get a set of gaskets from cometic in a .065 thickness for a drop in CR but then again it would go from say 10.6 to say 10.2.
Old 02-22-2007, 06:04 PM
kp
kp's Avatar
It will change a little between the 5.7 and 6.0 gasket even if they are the same thickness.
Easier to do 72cc heads IMO if you want to drop the compression..
Old 02-22-2007, 06:07 PM
I would be doing both if i go this route to drop compression!
Old 02-22-2007, 06:30 PM
eb02z06's Avatar
Kp is right-the bore diameter also plays an important role-Bro-did i tell you your crazy?
Old 02-22-2007, 07:48 PM
None crazier than you BRO!!
