Need Help Diagnosing Problem, Help!!
Old 02-25-2007, 10:47 PM
lowchevy2go's Avatar
Question Need Help Diagnosing Problem, Help!!
OK im stumped for the first time, Ok heres the problem. Im driving along and car is running great. All of a sudden it starts to surge and load up while at cruising speed. Then starts to backfire and go crazy. If i stomp on the throttle or rev it up it will clear up and run ok for about 30 seconds then gradually start to do the same thing, getting worse over the coarse of a minute or two. Then out of the blue it will be fine for 10 minutes or so.
I have changed
-MAF:
-Sparkplugs
-Plug Wires
What could be causing this. Im not throwing any codes. Could an injector be stuck open? Or o2's going out? bad coil?
Car background info:
98 ls1 ws6
ms3 cam
headers
80mm throttlebody
tsp td's
rear o2 sims
stock 98 injectors
tuned by mail order tsp tune, ran fine for 1 yr prior to it acting up.
Old 02-26-2007, 12:15 AM
snake charmer's Avatar
I am going to say it has to be either a spark plug or a spark plug wire not on to well . All it takes is one spark plug having a hairline crack for it to cause trouble . This has happened to me and I did not throw a code yet that was the problem .
Also the same thing could be with the spark plug wires not getting a good connection or a bad wire .
Old 02-26-2007, 12:20 AM
That's what she said...
TheBlurLS1's Avatar
Check all grounds, and make sure the battery terminals are clean and well connected. Sounds like an electrical bug to me.
The cracked plug problems usually surface when it's cracking up under WOT, if you're fairly sure about the plugs/wires, I'd look elsewhere. You could also just let her keep doing it the next time it happens and maybe it will throw a code. My car stumbles hard sometimes and ocassionally throws a MAF code when it happens, but I think it's the wires into the connectors messed up. Doesn't do it often enough for me to give a **** yet though.
Old 02-26-2007, 01:47 AM
staringback05's Avatar
check and see what your fuel pressure is...you could have a bad injector somewhere playn the gremlin
Old 02-26-2007, 09:35 PM
WHat should the pressure be and how do i tell if the injector is bad? just replace them?
I know the plugs are ok, and same with the wires. They are all new. Taylor 10.4's and tr55's
Old 02-26-2007, 10:36 PM
bump...
Old 02-26-2007, 10:39 PM
DSRCAM's Avatar
i had the same problem man this past week, i changed the 02 and it made it all better bro and i also changed everything like plugs, wires and maf
Old 02-27-2007, 11:51 AM
TheCarKid's Avatar
I had the same problem. I changed the O2's and the problem went away. Go for the o2's.
Old 02-27-2007, 02:59 PM
you can just plug a gauge into the fuel line and check it.....
i forgot about the front o2s...check them like the other guys are saying
Old 02-27-2007, 03:35 PM
rd_ls1_z's Avatar
Sounds like the same problem I had. It happened to be a plugged fuel injector. I had to check to see whether the left or right engine banks were lean or rich, and where the computer thought the misfire was occuring.
Old 02-28-2007, 12:56 AM
00BlueTA's Avatar
I had the same problem, It was a o2 censor. Hope you get it fixed.
