98 valve covers compatible with 99 coil brackets?
Old 02-26-2007, 08:31 AM
teke184's Avatar
Default 98 valve covers compatible with 99 coil brackets?
got my eye on some 98 heads/valve covers.
wondering how my 99 coil brackets will fit??
thanks
Old 02-26-2007, 10:05 AM
LS1Formulation's Avatar
LS1Tech 10 Year
No. '98 valve covers do not have brackets as the coils bolt directly to the covers.
Old 02-26-2007, 04:32 PM
teke184's Avatar
well i kindda knew that...
i guess what i'm asking is there a way to put my 99 coils on a 98 valve cover?
either by bolting the bracket on....or by pulling the coils off the bracket and bolting each on separately.
Old 02-26-2007, 04:41 PM
1320FEVER's Avatar
I think you can bolt the '99 coils directly to the '98 valve cover. I bolted my '98 coils to my '99-'02 valve covers, but I had to use the '99-'02 bracket.
It sounds like you are trying to do the opposite, so it seems logical that you can bolt the '99 coils directly to the '98 valve cover, you just don't need the bracket..
*edit* - you may have a difference in thread size so there may be a problem with the bolt size. I remember that I had to re-tap the holes in the bracket to get the '98 coils to fit the bracket..
Old 02-26-2007, 04:55 PM
silverlt1ss's Avatar
yea their work!!! zipt tie em on
Old 02-26-2007, 05:39 PM
teke184's Avatar
well i'm not gonna zip tie them perminantly...so i need to know about this possible thread difference
Old 02-26-2007, 10:17 PM
WILWAXU's Avatar
You should be able to bolt your 99 coils to a 98 valve cover.
Coils are the same. Valve covers and mounts are different.
Old 02-26-2007, 10:32 PM
lowchevy2go's Avatar
Yes they will bolt no problem, i have 98 coils on my 2002 heads. All the same
if they are goin on 99-02 you need coil brackets.
Old 02-26-2007, 11:44 PM
That's what she said...
TheBlurLS1's Avatar
You can take your coil packs, and bolt them directly to the 98 valve covers, no rails needed.
Quick Reply: 98 valve covers compatible with 99 coil brackets?
