My camaro cone crazy *HELP*
Old 02-26-2007, 10:00 AM
ELMiN8oR's Avatar
Exclamation My camaro cone crazy *HELP*
I'm in the middle of no where right now.
Any way i stoped at the traffic light where my gages light went low and the car start going like it has a cam with the service engine soon Logo came + check gages sing. When i turned of the car i waited for 15 minute and try to start the engine again it wouldnt start. The funny part was when i tried to start the car the trunk opened by it self. What could be the problem
Old 02-26-2007, 10:01 AM
shudog's Avatar
Sounds electrical. Take it somewhere and get the codes scanned to see what they are. Try resetting the computer, see the FAQ on how to. Give some more info, any recent mods added?
Old 02-26-2007, 10:08 AM
ELMiN8oR's Avatar
My recent mods are pacesetter LT, PS ORY, electronic cut-out.
Dude i'm in the middle of the desert and i'm using my mobile phone right now lol
Old 02-26-2007, 10:10 AM
Ls1LikeNoOther's Avatar
battery/alternator connections?
Old 02-26-2007, 10:16 AM
2001NBMZ28's Avatar
Is the car turning over at all? Check the battery connections - when mine died the rear hatch mysteriously popped too.
Old 02-26-2007, 10:17 AM
yea it sounds to be like a bad ground issue, everything going nuts..
ELMiN8oR's Avatar
my alternator is new but about the battery i just came out of the garage and he disconnected the battery and reconnected it back. Will this be the problem ?
Old 02-26-2007, 10:22 AM
I dont think so unless he didnt tighten them all the way, wiggle them, see maybe if you got a starter wire laying on the header?
Old 02-26-2007, 10:23 AM
YellowToy/A's Avatar
Make sure u have good connections all over.
Old 02-26-2007, 10:25 AM
ELMiN8oR's Avatar
I tried to start the car 10 seconds ago and it tried to start but it stops by giving me a "TIK TIK" sounds, if i'm not mistaken propably the battery
Old 02-26-2007, 10:27 AM
ls1amit's Avatar
Ground issue my friends did the same thing this weekend a gound wire snaped in half out of the blue.
Old 02-26-2007, 10:30 AM
Sluggish's Avatar
if there is corrosion on them....put coke on them....it with eat tham corrosion away
Old 02-26-2007, 10:36 AM
ELMiN8oR's Avatar
Where is it exactly.
i'll take a look now cause i have nothing to do exept fixing the by my self
Old 02-26-2007, 10:53 AM
the ground wire goes one to the innder fender, and correct me if Im wrong guys but the other goes to the engine block?
from the battery obviously
Old 02-26-2007, 11:03 AM
98Z28MASS's Avatar
Check your spark plugs and wires and make sure the plugs are all in pretty tight and that all the wires are snap on tight to the end of the plugs. Mine did what you described after my header install as i didnt have the plugs in tight enough and two wires were on loose. It started idling around 500 rpms almost dying out then would fluctuate up and down between 500 rpms and 1000 rpms until it died.
Old 02-26-2007, 11:34 AM
ELMiN8oR's Avatar
Thanks guys for the help.
Help is here,we are taking the car back to the garage.
And about the ground wire and spark plugs i'll be checking them also.
I thank you guys again for the help. I'll be posting back the prblem.
Old 02-26-2007, 11:41 AM
MeanTAWS6's Avatar
I'm gonna guess his battery just died, mine had those symptoms once. Jumped it, but all the lights were flashing periodically all the way home.
Old 02-26-2007, 12:08 PM
MavrikTA's Avatar
Yup battery. Had the same sort of thing happen to me. When these cars loose voltage, they go nuts!
Old 02-26-2007, 12:19 PM
2001NBMZ28's Avatar
Also thinking battery since volt gauge went down/check gauges light/clicking trying to start. Wondering about the new alternator too. Before my battery died and popped the hatch noticed the voltage was reading lower at lights with the AC on, ignored it for a couple days - luckily mine died sitting overnight in my driveway and not in the middle of nowhere.
Old 02-26-2007, 01:15 PM
bjamick's Avatar
Sounds like there is a loose connection somewhere. Prob something to do with his bro putting on the battery im sure.
