What can take more boost bone stock, an LS1 or LT1?
Old 02-26-2007, 01:43 PM
Forced 346's Avatar
Default What can take more boost bone stock, an LS1 or LT1?
Old 02-26-2007, 02:03 PM
LS1TECH Sponsor
DrTurbo's Avatar
LS1 can.....
As for what is more reliable when built with boost, I think an LT1 is.....
Old 02-26-2007, 02:23 PM
GrahamHill's Avatar
Neither piston is very stellar with high HP (unless you just make one glory pull and tell all your friends your making 700hp on stock pistons lol).
Old 02-26-2007, 03:01 PM
97blkz's Avatar
Originally Posted by DrTurbo
LS1 can.....
Explain this please?
Old 02-26-2007, 03:03 PM
JD_Z28's Avatar
I would think the LS1 just because the heads flow better.
Old 02-26-2007, 03:35 PM
LS1TECH Sponsor
DrTurbo's Avatar
5 bolts per cylinder > 4 bolts per cylinder.
You don't hear very much about LT1's lifting heads, or blowing head gaskets. Now granted the LS1 heads flow better so 1psi = more horsepower, but 1000hp on an LT1 is not to terribly difficult and somewhat reliable thanks to the extra head bolts.
Old 02-26-2007, 03:36 PM
seadoo's Avatar
the ls1 is a 6 bolt main, and the crank is good for 800-1000rwhp. its the stock rod bolts, rods, and pistons that suck.
Old 02-26-2007, 03:37 PM
LS1TECH Sponsor
DrTurbo's Avatar
Its the amount of headbolts that's the weak link.
Old 02-26-2007, 05:01 PM
seadoo's Avatar
yeah, that and the rods, pistons. too.... they lift heads alot
Old 02-26-2007, 05:07 PM
SS4Matt's Avatar
i believe it's the high cylinder pressure from FI on a stock LS1 piston that blows apart the ringlands, the high rpm's is what breaks the shitty rod bolts
Old 02-26-2007, 05:28 PM
GrahamHill's Avatar
The pistons will melt long before either had Any crankshaft problems or lifts any heads.
Old 02-26-2007, 05:40 PM
B.W.'s Avatar
The new LSX block coming out (or maybe it is out now) looks like this:
I'm sure you guys have already seen it, but there's a solution to a "weak link"
Old 02-26-2007, 06:49 PM
52172's Avatar
No **** this new block has 5 bolts per cylinder for the heads.
Old 02-26-2007, 07:03 PM
sytyjedi's Avatar
I would rather lift a head than blow everything out the bottom.
Old 02-26-2007, 07:19 PM
GrahamHill's Avatar
6
Old 02-26-2007, 07:27 PM
99Z28LS1's Avatar
i want this, would mean that i would have to get that 106mm and push the limits
Old 02-26-2007, 11:56 PM
otherwhitemeat's Avatar
will won't do either if its tuned right
Old 02-26-2007, 11:58 PM
94 slow's Avatar
How much boost does it take to lift the heads on an lsx?
Old 02-27-2007, 12:11 PM
JD_Z28's Avatar
Depends on how bad you're detonating
