Cats after mufflers?
Is there anything wrong with having the cats after the mufflers? The reason i ask such a rediculous question is that i am considering a setup like TheBlurLS1s old TD-under axle setup. If you're not familiar with it, its a tsp true dual system with the turndowns cut off, and a removable set of under-axle pipes that connect here and extend to the rear. Well, how about having the cats in the extended pieces? That way you can run dumped and loud, or quiet and legal.
won't work anyway because the cats won't heat up nearly enough to do what they're supposed to...
when I do my Y-pipe basically my cats will be directly off of the headers, most efficient way to do it as far as emissions are concerned
Kleeborp the Moderator™
Definitely won't be legal for the reasons stated...and if you want to follow the law to the letter, the cats can't be moved from the factory location, so even if you have cats on long tube headers at the header collector, they are still illegal in the strictest sense of the law (even though it may still pass emissions).
Location: The dirty taint of the country. ...Los Angeles
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by Sneakyws6
Because cats reply on tempature in order to properly burn off the emmission from the exhaust. The further away from the manifolds you get the lower the temps.
Originally Posted by TheBlurLS1
My dad has a '95 Chevy dually with a 454. It's got the hugest cat ever, and its AFTER the muffler, which is AFTER the extended-cab, bone stock.
Hey,.....don't some LS1s have cats further back from the manifold on the passenger side closer to the Y-Pipe?
Originally Posted by WS6 Rampage
****!!...wow!.simple yet awsome answer! Thanx!!! Makes sense!
