Turbo Motor For Lt1
I say build up the LT1...Your car is already setup for it for one, and it will cost you less in the long run and also the 5 head bolts will allow you to hold a little more psi without trying to lift the heads.
Im' about sell my setup which is 383. What should I do, I could buy or make new setup.This what I was thinking going with 355, AFR 210 ,TH-350 with trans brake 4000 stall.
sounds fine to me...Do some reSEARCH on different combos so you can get an idea of how much power you want, and then from there decide on what setup you think will make you happy.
I want to make about 900hp/1000hp .. Yeah I know this one guy got his mustang into 8's With custom Turbo kit , I spoke person made his kit iam looking 8 grand on whole kit .
We are building one right now...Single Turbo, 1000+ is the goal.
Engine -
Callies Dragon Slayer Crank
Callies CompStar Rods
JE Pistons (8.5:1)
Callies Splayed Billet 4bolt Mains
ARP Everything
AFR Eliminator LT1 Heads
SBC Intake, EFI
Custom Aluminum Elbow & TB
C&R Radiator
Turbo Kit -
Precision GT42-76 Turbo
Tial 50mm BOV
Tial 44mm Wastegate
Custom Manifolds
Custom Intercooler (Huge)
Exhuast -
4" Downpipe, dumped out the front fender
4.5" Electric cutout
3" Exhuast ran out back
EFI
Autronic SM-4
95lb Racetronix injectors
Boost, Fuel Pressure, Wideband and Temp guages
MISC
Rebuilt T56 with all the goodies (probably explode)
10 Bolt (lol)
BMR K-Member, A Arms, Subframes, TQ Arm, LCAs, Panhard, etc...
Custom 6 point cage
ZR1s with big M/T DR's.
Engine -
JE Pistons (8.5:1)
ARP Everything
SBC Intake, EFI
C&R Radiator
Turbo Kit -
Tial 50mm BOV
Tial 44mm Wastegate
Custom Manifolds
Exhuast -
EFI
Autronic SM-4
MISC
10 Bolt (lol)
Custom 6 point cage
