WOT timing?
Old 03-04-2007, 07:30 PM
99reddevilFRC's Avatar
Default WOT timing?
im @ 25* at WOT now. ive got a heads/cam package 224 cam 5.3 heads w/10.75 comp. ratio. is this low timing hurting me performance wise and if so approx. how much?
Old 03-04-2007, 08:07 PM
LS1TECH Sponsor
foff667's Avatar
There is no standard to how much timing you should run on a specific combo...there might be "starting" guidelines, but thats only a starting point. Your car might be maxed out with 25*...or it might not max out till 31*...the only way to know is either by track or dyno testing or both.
Old 03-06-2007, 06:27 PM
thanks, just wondering if any of you guys were running that low of timing since ive got a mail order tune.
Old 03-06-2007, 06:31 PM
SSpdDmon's Avatar
If you're in a good spot with your AFR, bump it up a couple of degrees and make a pass at the track or a pull on the dyno. That's the only way you'll find out. Just keep an eye out for KR. If you see any, back off it off while keeping the progress you made. In other words, it might like more timing before and after peak torque. But just because it only may like 26* of timing at peak torque doesn't mean that's optimal above and below peak torque.
Old 03-08-2007, 09:27 PM
thanks, will do. ive had several heads and cammed vettes and z28s and never had one have that low of timing but ive also never had one trap speed 126. thats the reason for questioning. thanks again.
Old 03-10-2007, 05:13 PM
SmaknaSS's Avatar
I think with 91 oct gas and 25* timing is a good starting point, Buy like someone said you need a dyno or the track to really tell.
Old 01-20-2008, 10:17 PM
colamotas's Avatar
SSpdemon what do you mean by "a good spot for afr"
Old 01-20-2008, 11:13 PM
Randy WS6's Avatar
get some tuning software or a hand held to watch your spark knock and timing,I run 27* on 93 oct. But a dyno will tell you were the sweet spot is , to little timing is just as bad a to much. Both can kill horse power and torque.
