Carburated LS1
Old 03-06-2007, 01:31 PM
cmdeoro's Avatar
Default Carburated LS1
I need to know what wiring is necessary if I were to do the LS1 Carburated on an 88 Iroc Camaro. It is obviuos that the injectors wont be needed and etc. But what will I need and will I need anytype of ecu.
Old 03-06-2007, 02:04 PM
62ls1's Avatar
You can buy the Edelbrock carb intake and timing module for around 650 - 700 bucks from jegs/summit, etc. The module comes with the necessary plug ins for cam sensor, etc. You won't need a computer to control the motor.
Old 03-06-2007, 03:47 PM
lionelc-5's Avatar
Default All you need
http://www.crateenginedepot.com/stor...-P1655C53.aspx
And that is it!
Old 03-06-2007, 04:26 PM
Roller406Bu's Avatar
Buy the MSD box seperately from them it comes with a program for your laptop to make adjustments to timing, also has a 2 step and seperate timing retard for nitrous...The box that comes with the edelbrock package does not have a port for your laptop...It comes with different plug ins instead for stock and mild setups...I'm doing a carbed 6.0 myself right now...Good luck.
Old 03-06-2007, 07:18 PM
PRAY HRD's Avatar
according to the instruction sheet, the #5 & 6 pills are for wilder setups. anybody running a larger cam with the edelbrock pkg, please chime in if the thread starter doesn't mind.
Old 03-06-2007, 08:04 PM
Im putting a MS4 in mine I'll post results in a month probally...
Old 03-06-2007, 08:22 PM
62ls1's Avatar
Yes but I think he meant with the Edelbrock controller ... I agree - it's probably a better bet to get the MSD one especially if you are going to spray it. I got mine for a good deal but I'll have to upgrade it later - at least it'll get me on the road.
Old 03-06-2007, 09:07 PM
PRAY HRD's Avatar
i went with the edelbrock unit only because i wasn't going to be spraying it and it was offered to me by a member on here for $200 shipped. i wonder who that masked man was?!
Old 03-07-2007, 08:30 AM
cmdeoro's Avatar
Damn, that is the best thing ever than. All you have to do is buy the MSD controller and it comes with all the wiring you need. SWEET! I have another question though. I was reading that the t-5 will bolt up to the LS1 but you need some sort of extension or something because the input shaft does not reach the clutch pack. Ohh... and thanks for all the help.
Old 03-07-2007, 08:58 AM
cmdeoro's Avatar
I forgot to add one more question. What carb do you guys recommend?
Old 03-07-2007, 11:10 AM
Darracq's Avatar
I have just a regular 750 vac, What kind of curv have you guys put in that have the adj msd box.
Old 03-07-2007, 11:25 AM
62ls1's Avatar
I will be using a holley db 750 cfm
Old 03-07-2007, 12:09 PM
bygblok's Avatar
I have a 750 mighty demon for mine when I get it going.
Old 03-07-2007, 12:25 PM
cmdeoro's Avatar
Alright cool, What about my transmission issue any ideas there?
Old 03-07-2007, 02:36 PM
Darracq's Avatar
I have a hesitation when i give a lot of gas, it pops back though the carb and then goes, I think i need a bigger squirter, anyone a good carb tuner?
Old 03-07-2007, 02:39 PM
PRAY HRD's Avatar
mighty demon 750. a mech secondary is recommended for manual cars.
here's a mockup pick from a few days ago.....
Old 03-07-2007, 02:40 PM
PRAY HRD's Avatar
not sure why you would want to go with the Ford T-5 tranny, always heard they were weak and you want to put one behind an lsx motor?! lol.
well, other than that i personally haven't heard of anyone trying to do that, but almost anything is possible. good luck with it.
Old 03-07-2007, 02:42 PM
AmericanMuscle313's Avatar
Where did you get the cool looking valley cover?
Old 03-07-2007, 02:43 PM
NemeSS's Avatar
stay with a ls1 t56 if u really need a manual,
dont even waste time with a t5, ive broken a few behind vortec head
motors, unless u have an all out gforce , racing trans.
dont bother with a t5, save for a t56
my $0.02
Old 03-07-2007, 02:47 PM
PRAY HRD's Avatar
well........i can't really say. a member on here who made it wishes to remain annonymous for now. of course, he's free to chime in if he'd like to. personally, i told him he needed to make/sell these NOW! it was a PERFECT fit and he gave me several options for personalizing it including lazer engraving it. i went the easy route with just a stamped bowtie emblem, but it's NICE!!!
Quick Reply: Carburated LS1
