Anyone With A 4l80e In A Chevelle ?
Old 03-07-2007, 04:41 PM
john 67's Avatar
Default Anyone With A 4l80e In A Chevelle ?
Im Planning On Laying In My Ls2 - 4l80e Into My Chevelle Within The Next Week Or So . I Would Assume I Would Want The Engine/trans As Far Back ( And As Low ) As Practical For Better Weight Distribution . Iv'e Installed A S&p Oil Pan And Have New Mounts And Offset Plates , The Engine Sits In Pretty Nice So Far. Has Anyone Done This Install In A Chevelle ? I Figure Ill Have To Do Some Cutting And Possibly Replace Or Modify The Dipstick Tube.and Relocate The Trans Crossmember .anyone With Pics Would Be Helpfull . Thanks John
Old 03-07-2007, 05:32 PM
pist0lpete's Avatar
I can say for certain you would have to move the crossmember back but you might be able to get away with the stock mounting pad. I had a 700r4 in mine before and it fit in the tunnel just fine but the 4l80e is a bit bigger but I could see it fitting with a little "massaging" with a big ol' hammer. I can't recall somebody specificly doing that swap. The 4l80e is tough but it sucks that it eats so much power.
Old 03-09-2007, 10:25 AM
TOOSLO5's Avatar
Got a 6.0/4L80 in my 72. Trans tunnel was cut out and replaced rather than made to fit with the hammer trick. I have great access to the trans lines, trans bolts and the electrics. The only issue i have run into so far is the shifter since the car is a column shift. I ordered a kit from Ididit and should have it today. If I get a chance it will be installed in the next week or so. As far as the crossmember went its been moved back and cut down a little. The TH400 crossmember was used for this.
Old 03-09-2007, 03:38 PM
john 67's Avatar
yeah sounds good , i have to replace some of the floors so i think ill cut the tunnel out, widen it and raise it too for some good room.what year is your 6.0?and what are you using to control the motor trans
Old 03-09-2007, 09:03 PM
LS1 SPEED's Avatar
Default Tooslo5
project is looking good
Old 03-10-2007, 08:43 AM
lt170chevelle's Avatar
Yeah i agree you will need a bigger trans tunnel. I have a 4l60e in my 70 chevelle and its right against the tunnel. I could jus imagine the bigger 4l80e.Definitely the crossmember needs to go back.
Old 03-10-2007, 03:44 PM
Dub Silverado's Avatar
I am putting a similar setup in my 70. 427 iron block backed with the 4l80e. I plan to start working on putting it in next week sometime. I need to figure out which oil pan to run first.
Old 03-10-2007, 04:00 PM
350SS's Avatar
I'm running a 6.0L/4L80E combo in my '72 using the stock crossmember, moved back and the mounting tab cut and welded to the back of the crossmember. No trans tunnel mods except for a couple of spots massaged with a bfh, but nothing major. I'm using a stock F-body pan and BRP style motor mounts. You can get away with this setup if you install the engine and trans separately...they won't clear the crossmember/firewall if you try to install them together. I have a little more angle to the driveline this way than I originally wanted, but I don't really think it should end up giving me any problems as long as my pinion angle matches up to it.
Max
Old 03-11-2007, 10:34 PM
john 67's Avatar
thanks for the info & the pics, its appreciated
Quick Reply: Anyone With A 4l80e In A Chevelle ?
