If you havent done the drill mod.....DO IT!!!
I know it is a old trick and everyone has prolly donte it, but the drill mod is the best thing I have done for driveability to the car. I cannot believe the amount of difference it made. It makes driving the car fun and easy. I used to be able to launch it once or shift at high rpm wot about two times and after that the pedal just sticks to the floor and it wont go into gear. Now after the mod it will not screw up at all. I HIGHLY HIGHLY recommend to do what every you can to get it done. It makes a huge difference.
Im kinda new to this... so can you send me some instructions on how to do it? Maybe a link. I just ordered a new clutch and hydraulics for mine and I think I may do it to the new MC.
All you do is drill out the restictor that is in the braided line that goes from the master to the slave. Well worth it, it makes high rpm shifting much better.
http://www.installuniversity.com/ins...sity/index.htm
Im with this guy. It has improved my shifting, and the pedal feels solid now. I would add that, If you have headers, to buy some radiator hose from discount, and some heat wrap kits for plugs and wrap that bish up!(works perfect, cut the metal ring out and slip it over the hose, then put the line in the hose), The heat from my headers may have boiled my fluid and led to failure of the hydraulics.
Originally Posted by SpdFrk1990
You guys that noticed a difference from the drill mod did you have dirty fluid b4 tho? Im thinking about doing this but im afraid some metal shavings could stay in the line and damage the slave or somethin.
You need to use a can of compressed air and clean it out once you are finished drilling and before installing.
Did you guys bench bleed it any special way b4 installing? I was just going to hook the line back up and have the mc and line all connected then hook up my motive power bleeder and open the quick disconnect to pre-bleed the system.
