Timing Chain-should I replace
Doing a cam swap and thought it would be a good idea to replace timing chain and oil pump while I am in there. I bought a new Rollmaster double roller from a fellow forum member. It seems like it is going to be a real pain to install. I am not even sure if it is "dot to dot" or both at 12 o'clock. Anyways, probably going with factory chain. Should I replace it, or just use the one I took out?
Thanks,
Thanks,
THese are Rollmasters directions, no more, no less
http://www.romac.com.au/pdf/Std%20&%...ank%20Info.pdf
Originally Posted by finallygot1
Not to sound stupid but the cam dot will be at 6 o'clock and the crank dot at noon?
Originally Posted by GuitsBoy
probably means oil pump, unless youre swapping your cam by dropping the gas tank...
LS2 chain is cheap and sturdy. Melling or LS4 oil pump have a lot of happy customers.
Originally Posted by Cop Car
there was discussion that the LS4 pump could suck a oil pan on an LS1 dry...
