L92, modifications to fit in a C5???
Originally Posted by See5
Mechanically it is just one engine mount or block that need an "adjustment". Clutch?
The rest of the knock sensor, cam sensor, TB stuff is cable related.
Clutch would be good info also....
You must either grind a lug off one side of the block or cut the engine mount to clear the lug. I chose to cut the engine mount but neither are a big deal.
The choice of clutch requires a LS1 pilot bearing and slave and TO, not LS7 or LS2 even with LS7/2 FW, or you can use heavy duty LS1/6 clutch/flywheel.
Originally Posted by 2c5s
My wife has the camera, sorry.
Also, is this the only alteration/modification that needs to be done...
Thanks any info...
Why can't you use the LS2 fwheel with the LS7 clutch? I have that setup in my car now and it works great, I have an LS1 though.
Do you know if this lug must be ground off when using a LS7 block?
You cetainly can just can't use the LS7 pilot bearing.
I totally read what you said wrong, I thought you were saying you couldn't use the LS2/LS7 clutch.
Thanks I thought that would be the case.
Somewhere on here I saw a picture of what needed to be modified on the LS2 block but I can''t find it now...
Yes, or modify the LS1 engine mount.
Found it!
Here is the post:
https://ls1tech.com/forums/showthrea...ht=motor+mount
And here is the picture:
Here is the post:
Originally Posted by SideStep
If someone could find and post those I would really appreciate it... I have looked also...
