Northwest Members WA, OR, ID, MT, WY, SD, ND
oil pump pickup tube bolt is a....
Old 03-14-2007, 12:55 AM
Camaros710102's Avatar
Default oil pump pickup tube bolt is a....
what a pain in the *** the oil pick up tube bolt is. I tied some fishing line to it and it save my *** when I took it out, started sweating bullets though
any helpful tips, fishing line...
Old 03-14-2007, 04:42 AM
99blancoSS's Avatar
I covered the opening to the oil pan with a rag to prevent anything from falling in.
Had to put it in with my body standing facing away from the motor. Reach down like you were picking up something on the ground slightly behind you so your cupping your hand backwards like a J and put the bolt up and in. Your facing away while your doing it. Its the only way I found that my hand and fingers would bend and conform to get it it.
Old 03-14-2007, 07:22 AM
WAHUSKER's Avatar
That is the single worst thing to have to do on these engines. I found a ratchet wrench with tape over one end works about as good as anything. Provided the oil pump is lined up properly, you can even use that to install the F-ing bolt.
You do need to loosen all the pan bolts & drop the pan as far as possible. I hear some guys take the motor mount bolts out & raise the engine a couple inches. A pain for sure, but that would make it easier. Sorry, not much help.....
Old 03-14-2007, 11:16 PM
Thanks for the ideas, I thought about the ratching wrench with tape thing today at work. So I went to Sears and bought the wrench and I'll probably have time to try it tomorrow.
Old 03-14-2007, 11:42 PM
TwoFast4Lv's Avatar
I found the EASIEST way is to do it while the engine is out
I know not the best option so dropping the pan is next. We have done a few
Old 03-14-2007, 11:51 PM
did you guys pull the bolts all the way out? I have just un-threaded them most of the way.
Old 03-15-2007, 07:57 AM
WAHUSKER's Avatar
You usually don't need to remove the bolts to get the pan to drop onto the cross member.
Old 03-15-2007, 09:14 AM
99blancoSS's Avatar
I had to unthread them most of the way. Its isnt easy with big hands. I had to do the reach down around, or have a friend with a smaller hand do it for you.
Old 03-15-2007, 11:59 AM
NataSS Inc's Avatar
A hell, just let it fall in the pan. I like the sound it makes when the crank shaft is grinding on it. Its almost hypnotic.
Old 03-15-2007, 10:14 PM
well today I got the bolt in, I tried the tape on the wrench thing but it didn't seem to work. What I ended up doing is taking a pair of needle nose pliers and holding it in place and starting the bolt with my right hand finger. I tightened the pan back up and oil pump as well. Just waiting on the spring tool from LSXChevelle.
Quick Reply: oil pump pickup tube bolt is a....
