odometer stop working
my odometer stop working,everything else in the gauge cluster works but that doesn't,ifi get a used one will it show my mileage or the mileage from the car it came from
Well if the car is a 98 then i think it is stored in the cluster itself so you would need to get it reprogramed.
What is wrong with the odometer? did the display go out or did it stop counting or something like that?
Originally Posted by 1meantransam
so the new one would automaticly reprogram to the car?
Originally Posted by blown 346
Your cluster is junk, You can get either a new one or a used one. But either of them would be re programmed to the current mileage of your car.
Originally Posted by Trust
Are you saying they would need to be, or they will automatically? If the latter, then no, mileage is stored in the cluster.
Copy & Paste Moderator
I dont believe there is a bulb you can replace for the odometer. It is built into the cluster.
You need a new instrament cluster. It's one unit and when one thing goes out the only way to fix it is to replace the entire cluster. It's the new 'plug and play' type of auto repair. 2 out of my 4 Pontiacs have needed it done. There are no user accessable bulbs to replace.
theres a bulb there, i cant remember who did it, i think it's in teh sticky up top. but he changed it to blue
edit
i'm so good it hurts
https://ls1tech.com/forums/appearance-detailing/436902-t-blue-odometer.html
edit
