I feel sick... don't work on your car late at night... help please...
Old 03-15-2007, 04:57 PM
Mike94ZLT1's Avatar
Default I feel sick... don't work on your car late at night... help please...
Ok I'm working on my car, I changed the valve stem seals. Putting everything back together, and I put my rockers on, and torque them to 22 ft lbs. I go and bump the motor over, so I could retorque them and make sure everything was good. LUCKILY my battery was almost dead, it didn't turn much. I forgot to put the rocker arm pedestal things back on, and trashed my pushrods. I broke one in half, and bent a few more. I was able to run to Livernois real quick and pick up a new set (Thanks Dave) and put them in, but do you guys think I did any more damage than messing up a nice perfectly good set of pushrods? I'm concerned I might have bent a valve. I feel really sick right now, so any help/input is appreciated. Thanks!
edit: the pushrods I bent and broke were TSP 7.4 .080 hardened ones if it matters, I relaced all of them just to be safe even though a few of them looked ok still...
Old 03-15-2007, 05:01 PM
LS1Formulation's Avatar
Ouch. Check everything over, I can't imagine it hurt anything but the pushrods. Look your rockers over VERY carefully to check for any bending or stress cracks.
Old 03-15-2007, 07:18 PM
DaddySS's Avatar
Unfortunately there's a fair chance that you bent valves. The pushrods broke because the valves hit the pistons or bottomed out. Do a leak down and compression test, that will tell you where you are.
Old 03-15-2007, 07:29 PM
ArcticZ28's Avatar
Lifters could be shot too.
Old 03-15-2007, 07:39 PM
pdd
pdd's Avatar
bent valves
Old 03-15-2007, 07:51 PM
Dragula's Avatar
Can you explain how that happened? I'm trying to picture it.
Old 03-15-2007, 07:54 PM
Silas2k's Avatar
i think ull be very lucky if u didnt screw a valve
Old 03-15-2007, 08:11 PM
GR33N GoblinM6's Avatar
i would also say your lifters may have suffered if you broke one in half.. thats a lot of pressure on a lifter...
Old 03-15-2007, 08:27 PM
heavymetals's Avatar
Bent valves.
Old 03-15-2007, 08:47 PM
GuitsBoy's Avatar
Do a compression check to see if youve got any bent valves. Its all speculation till you find out what damage has been done. Since those were HARDENED pushrods, there is a very realistic possibility those valves are VERY bent.
Old 03-15-2007, 09:44 PM
Mike94ZLT1's Avatar
All intake valves are bent. Picking up new heads in the morning, along with new lifters and whatnot. Dammit. I've taken these things apart a million times, I can't believe I forgot something that stupid.
Old 03-15-2007, 09:53 PM
landstuhltaylor's Avatar
that sucks
Old 03-15-2007, 09:58 PM
SDMForever's Avatar
It sounds stupid but I would pull your spark plugs out and see if they wre damaged that will give you a good Idea if the valves or anything else was trashed.
Actually the safest way to go is to take off the heads you dont want any loose metal in your combustion chamber.
Old 03-15-2007, 10:05 PM
Mike94ZLT1's Avatar
valves are definitely trashed... i'm posting from my garage where i'm pulling the heads now
Old 03-15-2007, 10:17 PM
Irocss85's Avatar
hey dont let that hurt your ego, lots of people make silly mistakes. its hard to see how you forgot those, but Ive done a few things like that at work over the years.
the worst one was swapping a fuel inj. on an older 4 cyl car, and the fuel ran right into the cyl through the inj. hole. sure enough, didnt notice that part, crank it over afterwards and boom. bent rod. doh!!!! live and learn buddy.
BTW, arent you the fella that sold me and my pops the convo pro's a couple years ago?
Old 03-15-2007, 10:18 PM
Irocss85's Avatar
and dang, you dont waste any time huh?
Old 03-15-2007, 10:40 PM
Cobra4B's Avatar
Damn dude... I know how it goes when it's late, you're tired, and you **** **** up.
Old 03-15-2007, 11:12 PM
JRracing's Avatar
Sorry to hear about your luck. I've almost screwed a few things up. That's why I always have someone check over my work. For a second opinion. It really helps.
Take your time, most of all. Good luck.
Old 03-16-2007, 12:18 AM
Mike94ZLT1's Avatar
https://ls1tech.com/forums/showthrea...31#post6658231
If anyone needs me I'll be in the back yard digging a hole to fall into after I shoot myself.
Old 03-16-2007, 01:05 AM
You just paid your dues to the MOD HELL CLUB.
