Which head gaskets for TFS 225 ?
I am installing into a stock bottom LS2 a 238/240 .605/.609 Comp Grind with TFS 225's c/w 61cc chambers in the next few days and am looking for some help from any smarty pants out there. According to my calculations with a .060 gasket I end up with 11.3:1 and 8.52:1 DCR. Should I use a thinner gasket to increase the DCR up slightly or should I leave it alone ? I also was thinking of just using GM factory gaskets but I dont know the thickness of them. BTW- I am in Central alberta where summer is only around 30*C and have 91-92 octane fuel.Thanks in advance for anyhelp.
Originally Posted by Brian Tooley
I would run the stock GM gaskets, but you could run thinner if desired.
What is the size of the combustion chamber on your heads?
Lot of the 4.00" bore head offerings seam to have a 4.100 chamber.
Any thoughts?
These ones have 61cc chambers...I dont think I would like to run any thinner than .040 as DCR would already be at approximately 8.64:1. Isnt optimum around 8.5 or so , or at least somewhere under 9:1 ? Please correct me if I am off and keep the comments coming, thanks.
Originally Posted by HEMIETR
I have the same heads. I used a Cometic 4.070 x .045.
My 4.070 is perfect for my bore and chamber. You definately don't want gasket hanging out into the bore.
Originally Posted by Fraser@speedinc
Interesting.
Any thoughts?
Any thoughts?
I have an update on compression ratio with the TFS 225 heads on a LS2 engine. I spoke to a customer of ours that goes by "rmitchell" on here, he has a C6 Vette with a stock LS2 shortblock. He originally had LPE LS6 heads with 11.5:1 compression and a 236/242 cam, he then switched to the TFS 225 heads and milled them to 12:1 compression. His power went from 480 RWHP to 507 RWHP, and the tendency towards detonation was actually reduced with the superior chamber design of the TFS heads.
Well we'll see what this does, should be together in a couple weeks I hope. I am shooting for 12:1 with 8.64:1 DCR with a .040 gasket will keep you updated. Why did he have to mill the heads to get 12:1 out of curiosity , am I missing something ?
I feel this is a better way to go than a bigger chamber with a thinner gasket, I prefer a quench of .040"-.050", it seemed to work for him, 12:1 with no detonation....
Just ordered a set TFS 225's myself through Canadian Performance.
Should be fun to see what she does on a 385ci motor w/ a streetable cam.
Brian, sent you an e-mail.
Than I have a problem because I somehow figured with 61cc and a .040(stock GM Gasket) would equal 12:1. Somebody help me out with my compression please. 61cc heads with stock 6.0L and .040 gasket= ? Thanks in advance.
Assuming your pistons are .005 out of the bore like mine. You use a .040 x 4.030 gasket. You would be at 11.9:1 with a .035 quench.
Alright, thanks, so you went with .045 over .040 ? Just to knock down your compression a bit more I assume , how does your car perform ?
