still no fix
still no fix
I have a 94 firebird with the lt1 350 and after hot cam install still pinging under load, idles eractly, surging up and downin rpm's unhooked mass air flow and idle is alot smoother, throwing no codes, readjusted valves, checked all wires and plugs, also still cranking weird like timing to high, it cranks slow, checked fuel pressure and it's good. Anybody have a clue please let me know before I have to burn it!!
Originally Posted by the_merv
You have it Tuned yet? The MAF Tables might be a little off..
I know you already did it, but sounds like 2 wires are crossed.
www.shbox.com, You probably already know that site, but just for guidance incase
Originally Posted by snk-huntr
By the way seen your video and of your car and it's a bad ride that's what inspired me to do the hot cam kit.
I ran my friends Hotcam LS1 M6 with pretty much the same stuff that mine has(Int/Exh, etc..), we went from 0-100, both of us with Drag Radials on and both of us got a shitty launch. We both took off at the same time, he pulled me by 3 carlenghts the whole race. That was a good Hot Cam vs. Hot Cam race.
yes i checked the opti twice its the spline type so it only goes in one way and maf is new
i have installed an opti on my 94 (spline type) they can go in wrong. my car ran like crap with it in the wrong position. the best way to install the opti correctly is to take a paint pen and mark the splines on top as they are installed correctly in the block. then put the splines into the opti and position the painted line to the top. that is how i indexed the opti correctly.
to reiterate you can install the opti and it isnt hard to do at all it happens with very little pressure
Originally Posted by jester1614
i just re read post #5 and that sounds exactly how my car was. your opti is installed incorrectly if you need me to explain what i mean pm me your number and i will call you.
Who did it for you.. I would have a little word with them..
