headers banging
generally it is the driver's floor board banging, and it is usually from a larger y-pipe, you could have an exhaust shop install a hanger there to stop all the banging and movement
I just installed my kooks headers and I had some bangging thought it was the Y-Pipe, but I noticed that the engine torques to the left (if you are looking down at it from in front of the car) anyway I had it up on ramps and took a peak underneath and noticed a rub spot on the first tube on the drivers side header, It was hitting part of the k- member, took a saws-all and cut a small factory weld that was sticking out, after that no problems...
I had a custom 3in y-pipe done and pace lt's. At first I didn't hear anything, then after a lil while the banging showed up. So i went to the garage and installed the anti banging hanger that the ws6-store sells and it cured the banging, looks cleaner then having stuff wrapped around the pipe IMHO. Don't wanna start anything.
Ben T.
Originally Posted by 99blancoSS
yep, poly. Anything else is just a bandaid to fix the real problem. Soft squishy mount flexing under load.
To use a cliche', you gotta pay to play.
Ben T.
