headers banging
Old Mar 21, 2007 | 08:56 PM
tonic's Avatar
Default headers banging
what to do, hitting my passenger floorboard is my guess, anyone have a fix for this??
Old Mar 21, 2007 | 08:58 PM
02silvaZ's Avatar
generally it is the driver's floor board banging, and it is usually from a larger y-pipe, you could have an exhaust shop install a hanger there to stop all the banging and movement
Old Mar 21, 2007 | 09:22 PM
tonic's Avatar
thanks ,
Old Mar 21, 2007 | 10:06 PM
Nemo02Z's Avatar
I just installed my kooks headers and I had some bangging thought it was the Y-Pipe, but I noticed that the engine torques to the left (if you are looking down at it from in front of the car) anyway I had it up on ramps and took a peak underneath and noticed a rub spot on the first tube on the drivers side header, It was hitting part of the k- member, took a saws-all and cut a small factory weld that was sticking out, after that no problems...
Old Mar 21, 2007 | 10:19 PM
waterbug1999's Avatar
Get some 1"-1.5" rubber hose and cut about 6/7" long. Pop rivet on both sides (where its bangin) and good to go.
Old Mar 21, 2007 | 10:45 PM
litle88's Avatar
I had a custom 3in y-pipe done and pace lt's. At first I didn't hear anything, then after a lil while the banging showed up. So i went to the garage and installed the anti banging hanger that the ws6-store sells and it cured the banging, looks cleaner then having stuff wrapped around the pipe IMHO. Don't wanna start anything.
Old Mar 22, 2007 | 12:01 AM
knight rider WS6's Avatar
I got the same hanger from the same place. Took care of the bangin.' The rubber on the hanger is up against my y pipe and cause more vibration at idle now. BUT!... N o bangin.'
Old Mar 23, 2007 | 02:12 PM
tonic's Avatar
just ordered them, thanks guys!
Old Mar 23, 2007 | 03:52 PM
z28_n_tx's Avatar
you could of just done the heater hose with a zip tie to keep it in place.....i think i paid like $3 ....been there for 9 months and no problems.
Old Mar 23, 2007 | 04:31 PM
Hard Core Z28's Avatar
What kind of headers is it? ]Mid lenght, long tube etc. That info could help a little bit. S
Old Mar 23, 2007 | 06:49 PM
tonic's Avatar
long tube, the fix is shipped out today, i didnt want to half *** my exhaust system tex
Old Mar 23, 2007 | 06:56 PM
litle88's Avatar
Tex you got some pics of your heater hose install? kinda curious!!!!!
Old Mar 23, 2007 | 11:54 PM
z28_n_tx's Avatar
ill take some pics tomorrow....looks ghetto and all but who's really going to see it....i didnt have *** it either....its just a cheap easy fix.
Old Mar 24, 2007 | 01:36 AM
99blancoSS's Avatar
motor mount
Old Mar 24, 2007 | 08:15 AM
tonic's Avatar
the polys??
Old Mar 24, 2007 | 08:16 AM
tonic's Avatar
if it looks ghetto then its assed
Old Mar 24, 2007 | 08:17 AM
tonic's Avatar
but thanks for the suggestion tex
Old Mar 24, 2007 | 09:52 AM
99blancoSS's Avatar
yep, poly. Anything else is just a bandaid to fix the real problem. Soft squishy mount flexing under load.
Old Mar 24, 2007 | 09:54 AM
Studytime's Avatar
This sounds like a good way to crack your headers when THEY have to absorb the torque the motor mounts used to.
Ben T.
Old Mar 24, 2007 | 09:55 AM
Studytime's Avatar
This is THE fix.
To use a cliche', you gotta pay to play.
Ben T.
