Progress pics of big boy LT1....
Old 03-22-2007, 11:56 PM
OutlawZ's Avatar
Default Progress pics of big boy LT1....
Made some good progress down at the shop in the past week helping out my engine builder (I do the menial tasks while he handles the big stuff).... it was cool however getting to watch over his shoulder and tutor me on little odds and ends he does to motors to prevent seal leaks, and the small stuff that the engine pros do when customers are usually away at work and home.... So in the last week we finished up the timing cover tig welding, bolted up the timing cover, finished the shortblock assembly, put the oil pan on after blueprinting the HV oil pump, checking main cap clearance and clearancing the pan rails. We're waiting on a smaller crank trigger to go with my new ATI balancer (got rid of my Fluiddampr), and we stripped down the heads bare so we can grind them to clearance them for the MONSTER manton pushrods (pic at bottom compared to a 5/16" hardened trick flow pushrod..... we're most likely about two weeks from "take this ************ home" status.... enjoy!!
Old 03-23-2007, 12:09 AM
daniel6718's Avatar
schweet
Old 03-23-2007, 12:35 AM
-PEPE-'s Avatar
Outlaw that looks awesome bro, that is going to be one serious beast when you're done. Can't wait to see some numbers from your beast man! , congrats!
dude look how similar our builds are , this is from last May/June timeframe 396 in the machineshop. I'm also using 3/8" pushrods, big as your friggin pinky.
Old 03-23-2007, 07:47 AM
Tony Shepherd's Avatar
Lookin good guys! Good luck getting your head studs to seal.
Old 03-23-2007, 07:52 AM
James Montigny's Avatar
Hell yeah, great pics guys.
Old 03-23-2007, 08:14 AM
-PEPE-'s Avatar
no kidding, mine leaked in the first 5 minutes, took 4 hours and a point of that K&N block seal, she's been fine though since last June.
Outlaw hope I didn't ya...just thought it was cool, saw the Canton pan, all the similar stuff....had to share some old photos from last year.
Old 03-23-2007, 08:40 AM
Ponyhntr's Avatar
Where do they leak from if they do?
Old 03-23-2007, 08:41 AM
Ponyhntr's Avatar
Lookin' good guys!
Old 03-23-2007, 08:43 AM
-PEPE-'s Avatar
right through the threads. some use various methods, like teflon paste on the threads, we used the sealant in the coolant method while running. Whatever you do don't do what GForce done and let it blow coolant over your brand new detailed engine, it's still not all off. You have to vent it from the overfill tube with a long hose to the ground. They didn't for whatever reason and it got over everything, including my fenders.
Old 03-23-2007, 08:52 AM
Ponyhntr's Avatar
Oh, ok. I was sure to use plenty of thread sealer, so I should be fine. What sealant did you use in the coolant, and is it available at a local parts store? Thanks!
Old 03-23-2007, 08:55 AM
LT1MAN's Avatar
Old 03-23-2007, 09:41 AM
OutlawZ's Avatar
awwww hell i ain't worried about your pics being there... they look awesome. thanks guys for the words...... yeah man our motor look hella similar... i'm using offset crower lifters which is the only thing i saw possibly different... and the single plane obviously different but didn't you just go to SP????? or did you just swap cams to SR?????
thanks again guys....
Old 03-23-2007, 10:12 AM
-PEPE-'s Avatar
she was already a SR, baby SR though, had a Crower lifter fail, chewed up the cam..so it was my excuse to get a custom grind by Allan @Futral and it's a FREAKING BEAST!!! (know it's not all about lift but still it has .708 lift ). The SuperVic gets ordered from PortPros after lunch, if I have enough in the bank ..
Old 03-23-2007, 10:22 AM
JUICED96Z
Guest
Posts: n/a
I can't wait till I get my motor out soon
Old 03-23-2007, 11:08 AM
9-Second Club
Ed Wright's Avatar
I used studs for years. Simply put a dab of silicone sealer on the stud threads before you screw them in the block. Don't over do it or you will find it in your radiator. I do the same with head bolts. Never have a problem.
Old 03-23-2007, 01:51 PM
OutlawZ's Avatar
yeah my engine guy says he has a way to do em so they dont' leak... some mixture of thread sealant and sumthin else...says it works everytime....
Old 03-23-2007, 02:33 PM
Moderator
BizZzatch350's Avatar
Awesome build, cant wait to see the car rolling some 8s
Old 03-23-2007, 02:45 PM
OutlawZ's Avatar
you and me both..... i told my engine builder yesterday that after all the stress and delays with building this motor (some his fault, some mine) that we are going to rent those sumo wrestler suits with boxing gloves and go about three rounds all out until someone is knocked out....
he told me that it will be terrible if I run in the 8's but take pictures after with a black eye...
Old 03-23-2007, 02:46 PM
Fire67's Avatar
Harold at PortPros used some blue stuff on mine... I couldnt get that particular stuff so I ended up with some other sealant similar to the gooey black aircraft gasket maker. I had to pull a head for a simple oil plug and that head leaked a little, the head I didnt touch (has the blue stuff) never has leaked.
Old 03-23-2007, 02:52 PM
Ls1Bait's Avatar
Looks good............
What are you using for your ignition? It would be hard to get a opti were you welded it up
Quick Reply: Progress pics of big boy LT1....
