Incon & K-Member
Incon & K-Member
I've done a search and can't come up with what I'm looking for . . .
What k-member ( if there are any ) will work with the Incon setup with no modifications? I know BMR at one time had one that worked, but do they still? I'm going to call them tomorrow but wanted to see if anyone on here knew . . .
Thanks!
- Dug
Thanks!
- Dug
Works with the stock K just fine
I wasn't aware it wouldn't work with any aftermarket K at all. The point of an aftermarket K member is to give you more room to work with. I believe all K members will work with the Incon. From looking underneath several times, there is no problem with an aftermarket unit.
I had to clearance my BMR k-member for my kit to work. Everything fit around it, but one of the intake hoses wouldn't go onto the turbo with the BMR k-member for some reason. Tried a couple times and everything was right so we just supported the car, dropped the k-member out, cut the corner off and welded a piece on it where we cut and it looks factory. Not sure if I'm the only one that has had to do this, but I've taken the engine off the k-member several times both in the car and out of the car and everytime it lines up the same. I'll see if I can dig up the pics of where we cut it.
It's been a while, but I believe the problem was on the passenger side. The rear mount for the lower control arm. On some k-members this was square on the inside. Where the factory is round. The Incon kit is real close on that side. I think they make them now with the corners clipped off at an angle.
