Cog setup on the street???
Old 03-27-2007, 10:40 PM
slowredz's Avatar
Default Cog setup on the street???
Is this doable at all? I dont daily drive the car but i do drive to the track and go to a lot of GTG's (2 a week maybe when the weather is good). Those belts are kinda expensive to be replacing all the time ... If not what else? 12 rib? Who sells a setup that will work for me??? This will be a F1R setup by the way...
Old 03-28-2007, 03:15 AM
EPP
EPP's Avatar
I don't know of any cog systems by anyone that are available for the LS1 F Body's. I also haven't seen anyone convert one to a 12 rib. There isn't much room under there... Bob
Old 03-28-2007, 07:34 AM
V6 Bird's Avatar
Anything can be done with some custom fab work.
Andrew used to drive his car with a cog belt setup Josh.
Old 03-28-2007, 11:10 PM
topgun77's Avatar
I know speed inc had a cog set up on there D1 way back in 02 or so......I have seen a few guys try to run them on the street and they would rip through belts and they are not cheap. So to answer your question no I have never seen a street car do so with great success
Old 03-28-2007, 11:33 PM
xssive's Avatar
ATI jsut released a dampener/pulley system for cog/10/12 rib setups on ls1s
http://www.atiperformanceproducts.co...-kit/index.htm
Old 03-28-2007, 11:56 PM
slowredz's Avatar
Thanks man I will probably give them a call in the morning...
Old 03-29-2007, 07:42 AM
WAHUSKER's Avatar
I looked into their cog system (nice - it has a clutch). But it's 3" wide! My 8 rib is jut over 1" and it's a tight fit. So while I want one, I'm not going to cut/move/weld the radiator support forward 2" to make it happen. There is probably room for a 12 rib, but nobody makes a kit.
Old 03-29-2007, 07:53 AM
V6 Bird's Avatar
Let me tell you this bro...With the box that just showed up at Ray's shop with someones blower in it...Theres a cog setup in there Its sweeeeeeet too
If you need something from ATI let me know. Chris is a dealer of theres now, and we also are sponsored by them.
Old 03-29-2007, 09:44 AM
turbo's Avatar
This for a LSX? What size blower?
(edited)
Old 03-30-2007, 07:35 AM
V6 Bird's Avatar
(edited)
Yes and its a D1.
