fitting for boost vac reference??
Old 03-28-2007, 10:57 AM
Eatinstang4life's Avatar
Default fitting for boost vac reference??
I am looking for I guess a double t fitting that I put in my brake booster line to reference my wg, boost gague, and bov from. Or can I just put a singele t in and than t the line off I put I connect to that t. lol
Old 03-28-2007, 11:13 AM
SSilverSSurfer's Avatar
check out that golden eagle piece that superman used, looks good
Old 03-28-2007, 01:13 PM
89Formulaws6's Avatar
why do you need to put it in the brake booster line?
granted i haven't looked under the hood of my ls1 for vaccum lines since i just got the car over a week and a half ago but a normal sized vaccum line will be good enough
Old 03-28-2007, 03:02 PM
cablebandit's Avatar
http://www.ls1gto.com/forums/showthread.php?p=2270822
i went to mcmaster carr and just ordered the same one but with only 4 ports...dont need 7
Old 03-29-2007, 06:41 PM
I might get one of those manifolds. If not I can just t off the wg reference right?
Old 03-29-2007, 07:16 PM
JAvenger007's Avatar
you could but id get one of those mcmaster parts. nice units and cheap. anybody remember the size of the brake booster? Forgot what size barb is needed for them.
Old 03-29-2007, 07:38 PM
i just got my fittings today....i think the booster hose is 1/2 inch.
Old 03-29-2007, 08:07 PM
thanks.
5469K115 is the part # for those interested. its got 1/2"NPT inlets (should be same as brake booster) and 3 3/8"NPT outlets. So you just need to get 3/8" NPT to 1/4" barb adapters for the vacuum lines (and of course the 1/2" NPT to 1/2" Barb adapters)
Old 03-29-2007, 08:29 PM
damn that thing is 20 bux Nice unit though i ordered one up with the other neccessary fittings, thanks guys.
I Think Mine Was 1/4 In/out With 1/8 Holes For The Barbs
Old 03-29-2007, 08:37 PM
I was thinking about the 1/4" inlet one since its only $11 but i was thinking it would be a restriction given the booster is 1/2". Does it not matter?
Old 03-30-2007, 05:00 AM
1a-play's Avatar
I just ordered one also- brake booster line is 1/2 , thanks for the info on the piece cablebandit
Old 03-30-2007, 06:34 AM
No Juice's Avatar
Another thing I need to get
Old 03-30-2007, 06:42 AM
trans2000am's Avatar
is this the part number for the four outlets just to make sure 5469K125
Old 03-30-2007, 07:35 AM
also are these the adapters for it 5346K25, and 5346K24 dont wanna order the wrong parts.
Old 03-30-2007, 08:49 AM
did you get the 1/4" in/out one also?
5469K111 is the part # for the $12 1/4" manifold. The 1/2" cost $20. Its part number is 5469K115. I think ill go ahead and get a 1/4" one if size doesnt matter. I was concerned that it would be a restriction.
Quick Reply: fitting for boost vac reference??
