A2A with 4" Inlets
Old 03-30-2007, 11:32 AM
Juiced's Avatar
Default A2A with 4" Inlets
Has anyone seen an FMIC with 4" inlet and 4.5" or larger outlet?
Old 03-30-2007, 12:31 PM
DeltaT's Avatar
Yes. Of course you would need a 4.5+" core. I could have gone with 4" inlet/outlet on mine (4.5" core) but chose to stick with 3".
www.bellintercoolers.com
Jim
Old 03-30-2007, 12:38 PM
andereck's Avatar
ProCharger offers an A/A that measures 27 x 12 x 6 and has 4" inlet/outlet ends. It is a monster.
AI006A-002 same side inlet/outlet
AI006A-001 opposite inlet/outlet
Old 03-30-2007, 12:47 PM
Juiced's Avatar
with a true s95 turbo you need at the minimum a 4" inlet. the od on the discharge is 4.5"
Old 03-30-2007, 02:05 PM
smokinHawk's Avatar
im going to cut and weld my OBX to have a 4" out soon
Old 03-30-2007, 03:44 PM
Pathological Modifier
Ryan K's Avatar
It would actually be more benificial to have the inlet larger, The air comeing out of the turbo is at its hotest. Therefore occupies a larger area. Once it comes out of the intercooler it is denser and has just passed the largest restriction in the intake tract...
Just my opinion, Either they should be the same size or the most benifit woul be at the inlet.
Ryan K.
Old 03-31-2007, 09:30 AM
smokinHawk's Avatar
its just that i have a 3" outlet from the turbo, and a 4" inlet from the throttle body. matching the pipes it wil have less restrictions, and look better.
Old 03-31-2007, 03:03 PM
stevieturbo's Avatar
Has anyone done any actual testing on the cores they are using, for pressure loss across the core ?
Quick Reply: A2A with 4" Inlets
