installing tubular k member with engine in
Old 04-01-2007, 07:32 PM
udlose99ta's Avatar
Default installing tubular k member with engine in
how much harder is it to install with the engine installed? Is there anything special i need to do? thanks..
Old 04-01-2007, 08:41 PM
ls1pwrdss's Avatar
keep the engine supported
Old 04-02-2007, 09:27 PM
1970judge's Avatar
HM...im not saying its impossible but what the hell for? Seems much easier dropping the motor too cherry picker to get engine to new K member install back in..
Old 04-02-2007, 10:53 PM
DONAIMIAN's Avatar
because if you drop the motor, you have a lot more stuff to disconnect. Fuel lines, grounds, wire harness, the tranny comes with it, disconnect the driveshaft, remove the shifter, taking off the torque arm.
Old 04-02-2007, 11:13 PM
Revelation Z28's Avatar
if you have a STB, you can let the engine "hang" off of it with a chain while you unmount it and drop the old k member.
Old 04-02-2007, 11:35 PM
DONAIMIAN's Avatar
I wouldnt trust a STB to hold up my motor while I was under it changing out a K-member.
Old 04-03-2007, 08:18 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Why not? You're talking about a 1.5" peice of steel or aluminum holding up 250 lbs. Also, with the trans still connected to the trans brace, it's not holding all of the weight.
When I eventually get a k-member, I'll put the car on my bro-in-laws lift, throw a trans jack under the trans and swap out the k-member. I will put a pair of supports from each head up to the shock tower brace to keep the motor from rocking, but I wouldn't be worried about it falling.
Old 04-03-2007, 08:49 AM
TWS
TWS's Avatar
If somebody pulls the motor just to do a K-member swap, then they are definitely a masochist.
Bolt on a strut tower brace and use a tie down strap.
Been there and done that and it works great.
Old 04-03-2007, 09:14 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Agreed, get the proper engine holding tool, its bigger, beefier, boxed tubing that connect to the strut towers, it is designed for this specific application
Old 04-03-2007, 11:19 AM
LS1TECH Sponsor
Steve Burger's Avatar
I used a wood 4x4 to support the engine.
Old 04-03-2007, 07:27 PM
ls1pwrdss's Avatar
put the car on 4 jack stands all the way up. take you floor jack and a 4x 4 and support the oil pan and the remove the k member. this is how i did it before i had a lift.
Old 04-04-2007, 11:26 AM
blackbyrd's Avatar
im surprised no one mentioned using a cherry picker to hold it in place and just drop the k member out the bottom? unless i miss read
Old 04-04-2007, 01:17 PM
DONAIMIAN's Avatar
I would use either this method
or this method
When it all comes down to it, its about how safe the person thats working on the car feels. If your fine with a STB go right ahead. Keep in mind a fully dressed LS1 weights 458lbs
Old 04-04-2007, 05:18 PM
jtcWS6's Avatar
I used a cherry picker to hold the LT1 in place and droped the k member out the bottom. Worked great for me, actualy I rented the cherry picker from a local shop and he wanted to sell it so I picked it up on a cheep price.
-Justin
Old 04-05-2007, 12:53 PM
Internet Mechanic
Your betting your life, hoping the hydrallic fluid pressure will hold, just like having a car resting on a set of hyd jack's instead of stands, eventually its going to give out
Quick Reply: installing tubular k member with engine in
