What's wrong with this picture?
Old 04-05-2007, 06:53 PM
joshluther's Avatar
Default What's wrong with this picture?
It just started this today. 1st and 2nd seem fine 3rd and fourth are slipping.
It happened way to fast. It hasn't ever slipped.
Old 04-05-2007, 07:06 PM
LS1Tech Sponsor
performabuilt's Avatar
I am not sure but 22mph in 4th gear?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-05-2007, 07:18 PM
joshluther's Avatar
At 2000 rpms!! Input shaft rpm is only 774
Old 04-05-2007, 07:32 PM
LS1Tech Sponsor
Well i didnt see the 456 gears so 22 mph in 4th is not so unreasonable.
But assuming this is a 4l80e since it has and input speed sensor .
Stall being 3000 that could be correct along with the difference in engine to input rpm. Provided the converter is not locked but unless i am missing something it looks like it is bearing in mind Im no tuner
__________________
Call 888-744-6542
Old 04-05-2007, 07:39 PM
joshluther's Avatar
It's a 4l60e in an 04 truck
Tranny has these upgrades with 15K miles or so on it.
Bushing Kit, Master Overhaul Kit, New OEM Style Filter, Updated SKF Input Sprag, New Washers And Bearings, Updated Low Roller Clutch, New Steel Oil Pan, Raybestos Indy Red Clutches, Reprogrammed & Updated Street & Strip Valve Body, Valve Body Spacer Plate, New Internal Wire Harness, New EPC Solenoid, New Shift Solenoids, New Speed Sensor, New 13 Van Pump Rotor, Corvette 2nd Servo, Super 4th Gear Servo, New Selector Shaft, Raybestos Pro Series 2-4 Band, Upgraded Beast Sunshell, Molded Steel & Rubber Pistons For Input Drum.
The convertor is a Yank TT3000. The 408 has only been in a week and I haven't been razzing on it to bad.
Normally 2000rpm in 4th locked I'd be doing about 60mph The tires are 30" high.
It seems like it's skipping 3rd gear but slipping in 4th
Old 04-05-2007, 07:41 PM
LS1Tech Sponsor
Well now I am really confused unless the numbers are estimated in the PCM since a 4l60e does not have and input speed sensor hmm .
But based on that information Im gonna go with a failed or failing 3-4 clutch
__________________
Call 888-744-6542
Old 04-05-2007, 07:47 PM
joshluther's Avatar
It shifts fine cold but all hell breakes loose when it warms up. Would the clutch just give up all in one day? It was fine yesterday and today it won't move in 4th.
Old 04-05-2007, 07:54 PM
LS1Tech Sponsor
A sealing ring or rubber seal could have broken. But yes it can happen in a day or even a few minutes
__________________
Call 888-744-6542
Old 04-05-2007, 08:01 PM
joshluther's Avatar
Shoot me a Pm with what it would cost for you to go through the tranny and upgrade to your level 3. Thanks Josh
