Cam Install help
Old 04-06-2007, 07:10 PM
kevins2000LS1's Avatar
Default Cam Install help
i was wondering what you do-it-yourself guy use to hold the lifters up. I know there little plastic clips that SUSPOSE to hold the lifters up if you spin the cam. And i know about the pen magnet trick, but i have seen a few guys use a wood dial, i can get all different size pieces, just dont know what size to use and how long. PLEASE CHIME IN
Old 04-06-2007, 07:48 PM
HEMIETR's Avatar
1/4 or 5/16. Make them long enough to reach the rear of the engine.
Old 04-06-2007, 08:28 PM
silverZinSD's Avatar
I used 1/4 wood dowels. To make the right length, make it about 6 inches longer than your cam. That has worked everytime for me and it only cost 83 cents.
Old 04-06-2007, 08:42 PM
bayer-z28's Avatar
^ SWEET! Thanx for the advice, I'm also doing a cam soon, and didn't feel like buying the "special" metal pieces.
Old 04-06-2007, 10:07 PM
WS6WRX's Avatar
Aluminum rods in the same size work great as well, I had to bend mine a little and didn't want to worry about breaking a wooden one cause I seem to have that kind of luck.
Old 04-06-2007, 11:48 PM
Thanks for the input guys, im doing the swap now and had to stop. So i fiqured that i would ask before getting back started.
Old 04-08-2007, 12:08 AM
I used some 5/16 alumium rods and took the grinder and ground a flat spot all the way down one side and they worked perfect AND only $4.15. Now im trying to fiqure out how to find TDC on the #1 with the pusrods and rocker arms off. I have the cam dot-to-dot just dont know if its 180 degrees out?
Old 04-08-2007, 06:31 AM
Moderator
davered00ss's Avatar
JRP cam install tool here.
Old 04-08-2007, 11:34 AM
SlowazzVette2's Avatar
If its DOT to DOT then it should be top dead center. I used ls1howto.com for my first cam swap. It has very helpful info.
Old 04-08-2007, 02:10 PM
CASHss99's Avatar
i used wood on passenger side slid right in then metal on the other slid right in.... the passenger side didnt need any grinding done to the rod just be patient worked for me
