egr block off plates
i`m thinking fo getting a set and was wanting to know if any body has had any problems with it and if anybody has had any advantages with it. please post and let me hear your opinion it is welcomed
Location: king of prussia, pa (home) and williamsport, pa (school)
these are only necessary if your doing longtubes w/out emission fittings. you dont need to waste yoru money on the expensive ones online. get yoruself a peice of sheet metal and some metal sheers. take off the existing egr plates, trace around them on the sheet metal, and cujt them out. drill holes accordingly.
have fun
have fun
use the gaskets instead of the egr valve itself if you plan to make your own. Much easire to trace. I bought mine from UMI, but dont delete EGR if you arnt getting non-emission LT's
nice pic on your post!! but my problems that i have emission legal lt`s but there leaking at the egr tube connection and i found premade kit for $30.00 at herron
performace.com
performace.com
I ebayed my block off plates for like 15.00 shipped. But if you have access to some scrap sheet metal (aluminum) go for DIY block off plates they're very straight forward to fabricate.
I forget which it was, AIR or EGR, but I took the factory plate that had a steel line running through it, dremeled the steel line and then plugged the resulting hole with a quarter and JB Weld. Cost me 25 cents and it's holding up damn good compared to the pricey block-off plates.
