11 sec camaro
11 sec camaro
If you had a 400RWHP m6 full wieght camaro what supporting equipment would you need for a 11.99 run. DR? Nittro's enough? Rear suspention?
Other that engine work the vehicle is stock.
Couldn't really find it under a search, looked through the 11 sec club and think its enough HP but will need more traction. If so saying you were cheap I have 16 and 17 inch rims, what tires?? size?? used??
That should be enough power or at least very close to it. A lot depends on the suspension and launch. I know there was a guy around here going 11.5 at 120 with 420 rwhp and M6, however he was getting like 1.45 60ft's and pulling the fronts.
Yea, I mean I know someone with 340 HP to the wheels that is running low 11's, drag racing isnt all about HP, so yea 400 HP is more then enough to do 11's if your car is setup for it
theres a guy here runnin 10.80s with stock internals,but i think the car weighs around 2800lbs.so 400 with a good setup in a full weight car will easily do 11s in good air and at a good track
