Weld wheels
Old 04-14-2007, 03:15 AM
LT1Z/28's Avatar
Default Weld wheels
on the rear, to run a 10 inch weld draglite, what backspacing is needed so it will look right and fit?
Old 04-14-2007, 03:31 AM
Ls1Bait's Avatar
5.5" backspacing. I have weld draglites on my car
Old 04-14-2007, 07:05 AM
Row
Row's Avatar
7.5" backspacing fits under the car and looks good.
Old 04-14-2007, 08:19 AM
dhdenney's Avatar
I think 5.5" would probably be for an 8" Draglite.
Old 04-14-2007, 10:09 AM
the_merv's Avatar
Anyone have pics from the Rear with a 15x10, on it, and put the Backspacing if you can..
Old 04-14-2007, 12:47 PM
hashtagBMW
Speed Density's Avatar
15 x 3.5 = 1.5
15 x 8 = 5.5
15 x 10 = 7.5
Those are the normal 4th gen drag wheel offsets, using those will keep your car from looking redneck with your wheels sticking 6ft out the side of your fender.
Tony.
Old 04-14-2007, 01:00 PM
the_merv's Avatar
Cool. What size is the MT ET Street's on there, and how much did you have to modify on the inner body there?
Old 04-14-2007, 01:34 PM
streetwarrior96's Avatar
7.5" in 15 x 10"
Old 04-14-2007, 04:40 PM
hashtagBMW
The MT Drag Radials on there are 275/60/15. Other than grinding the calipers and pulling the lower fender lip back, nothing else is need for them to fit.
Tony.
Old 04-14-2007, 04:51 PM
DroppedM6Z's Avatar
They make a 15x10 with 6.5" BS that looks alittle better than the 7.5 if you ask me. I've got a set on mine with the 2" drop and they clear everywhere. Nothing touches at launch.
Old 04-14-2007, 05:05 PM
fergymoto's Avatar
^What size rear tire are you running? Any pics from behind or at an angle from the back?
Old 04-14-2007, 05:11 PM
DroppedM6Z's Avatar
11.5x26, and i think i do.....let me look
Old 04-14-2007, 05:25 PM
fergymoto's Avatar
Is 11.5 the tread width or section width? Did you have to do any hammering or bending for clearance? I am looking to run a 325/50-15 which is a 28" tire with an 11" tread with and 13" section width. I know a 15x10 with 7.5" backspacing would work good on this but I am trying to figure out how a 6.5" backspacing would look and work.
Old 04-14-2007, 05:28 PM
the_merv's Avatar
That looks sharp... more pics..
Old 04-14-2007, 07:14 PM
DroppedM6Z's Avatar
The only other pics are of it pullin the wheels.....
Old 04-14-2007, 07:17 PM
DroppedM6Z's Avatar
I think 11.5 was the section....The 13" section is going to require more than a hammer I was under the impression that the 50 was a 26 and the 60 was a 28, am i wrong?
Old 04-14-2007, 07:32 PM
the_merv's Avatar
Not necessarily, they are 325's, so saying 50 as a sidewall would make it around a 28" tire. The 50's as a 26" and the 60's as a 28" is the MT ET Street Tires, the 255's.
Old 04-14-2007, 08:13 PM
DroppedM6Z's Avatar
maybe a 40 is a 26..... idk
Old 04-14-2007, 08:56 PM
the_merv's Avatar
Here is a good setup from what you guys have been sayin..
http://store.summitracing.com/partde...5&autoview=sku
Old 04-14-2007, 09:06 PM
fergymoto's Avatar
^Those are the tires I have been planning on. I will probably get Draglites, they look good on both TAs and Camaros. I think maybe slightly more so than Pro Stars. 15x10, was sure on 7.5 backspacing but now I was to see what 6.5 would look like.
Quick Reply: Weld wheels
