Input drum and shaft?
Old 04-15-2007, 07:13 PM
Kiss_My_99SS's Avatar
Default Input drum and shaft?
I have a 99 camaro 4L60e trans. What year and model input drum and shaft will work ? Like a 2005 4L60e input drum and shaft from a truck?
Old 04-15-2007, 08:31 PM
FLT
FLT's Avatar
You can use any drum that is 98 and later. You do need to make sure that it is a 300MM style. I can get you a drum and swap the shaft for you if you would like. Send us an email or give us a call if you would like to go this route. Vince
Old 04-16-2007, 10:45 AM
How do you tell if it's a 300mm style?
Old 04-16-2007, 04:24 PM
PBA
PBA's Avatar
It does not have the torque converter clutch seal at the tip of the shaft. The seal will sit just behind the teeth. It will have 30 splines, and measure around .990" OD.
Quick Reply: Input drum and shaft?
