Side Markers? Help a Girl?
Hey..
anyone know where I can buy smoked side markers
for my 98 T/A?
Or if someone can help me on how to paint them so
I can wax them and the wax wont take the paint off.
[The wax is taking the paint off my CETA.. :[ my dad
said we didnt need anything specific for it.. and now the
wax is taking it off ]
Please let me know thanks!
-Chelsea
for my 98 T/A?
-Chelsea
no I use 5star
the CETA was wet sanded with idk what sand paper, wiped down with a denatured alcohal and dried with a microfiber towel, then coated with semi-gloss "plastic" paint [4 times] and not clear coated.
Could the clear coat be the issue?
And with the side markers
They are still stock looking but I'm afraid of doing the pain myself
and having the wax take it off and or the paint chipping and cracking from heat..
All paint should be clearcoated. I would have it repainted, and use primer and clear coat this time around. It's just going to keep peeling.
If you search on ebay, you can find smoke rear signal lights. Haven't found anyone that makes the fronts though.
http://cgi.ebay.com/ebaymotors/98-02...QQcmdZViewItem
You would have to run a bead of silicone around the lense to keep moister out.
I did find this though.
http://cgi.ebay.com/ebaymotors/SMOKE...QQcmdZViewItem
If it's a vinyl, then wax won't take it off.
I promise you can do the side markers, and if you some how find a way to screw them up, all you have to do is sand them and try again. You can buy vht from california custom coatings. Just google the company and you should be able to find it. With the side marker, just clean them with windex, lightly spray a coat, let it dry, and then repeat till they are as dark as you want them. You don't have to be afraid of going too dark because when you sand them to clear coat you'll probably take off some of the tint anyways. After you vht them, wet sand them with like 600 grit, clean them again, and then spray the clear coat. If you need to, sand again and then put down another layer.
I use mequires for everything. They make good stuff. If you need some VHT Niteshades I know a guy who is selling them. I just bought two cans from him. Here I'll give you his info. His name is Travis. I'll have him get on this thread.
Here is the paypal Addy...
sales@gvperformance.com
