Broken tranny again
Old 04-21-2007, 05:51 PM
zdriven28's Avatar
Angry Broken tranny again
Well I have a 4L60E transmission and last night it broke.... again! The tailshaft is the only thing that breaks, and completely around. Does anyone here know what can possibly be causing this? Its happened to me twice already. Yall's help would be greatly appreciated.
Old 04-21-2007, 05:53 PM
FLT
FLT's Avatar
Have you been feeling any vibrations, also do you have the torque arm still mounted on the tail housing?
Old 04-21-2007, 05:55 PM
LS1Tech Sponsor
performabuilt's Avatar
LS1Tech 10 Year
I am assuming you nean the tail housing , Gnerally if they break its a drive shaft suspension geometry issue.Also check your front ujoint that it does not have a tight spot in it ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-21-2007, 06:53 PM
zdriven28's Avatar
I actually do have the torque arm on the tail housing still, I was guessing maybe that had something to do with it. Ive heard they sell torque arms that relocate somewhere other than the tail housing, Im interested in buying that wherever I can find it. As far as vibrations, I feel em but I think its from my x-pipe.
Old 04-21-2007, 06:55 PM
zdriven28's Avatar
Now that you mention it my friends have also said it can be a drive shaft suspension geometry issue. But where would I take it to be sure wether its due to torque arm issues or geometry issues?
FLT
FLT's Avatar
Look at the list of sponsors for the cross member. Try UMI, BMR, Spoon, and I'm sure that there are a couple of others that I have forgot. Have you replaced the drive shaft or had it checked when you broke the other housings? Might be a good idea to address that as well. Vince
Old 04-21-2007, 06:58 PM
FLT
FLT's Avatar
I'm not sure what shops are in your area but pinion angle is one of the things to have them check.
Old 04-21-2007, 07:02 PM
zdriven28's Avatar
Well actually first time it happened my cousin owned the car , he bought a completely new transmission before that happened. I bought it recently and felt that it was possible it would happen again and it did last night. Ill definately get it looked at though, would I have to have the drive shaft checked while it is on the car?
Old 04-21-2007, 07:06 PM
FLT
FLT's Avatar
Well there are a couple of things to look at as far as the drive shaft is concerned. The length of the shaft, balance of the shaft, pinion angle, and also is it bent, which they will definitely be able to see when it is checked for balance.
Old 04-21-2007, 07:13 PM
zdriven28's Avatar
Ill definetaly get that checked, might as well invest in a relocated torque arm as well just in case. I appreciate the help man, this was starting to become a nuiscance esp. since Ive helped out to remove the broken housing and replace it the last time around.
Old 04-21-2007, 07:22 PM
FLT
FLT's Avatar
Your welcome. I don't mind giving some advise when I have free time. Good luck and feel free to give me a holler anytime if you need something. Vince
Old 04-23-2007, 11:10 AM
Retired Street Racer
Matt D's Avatar
You have the stock steel driveshaft don't you?
Old 04-24-2007, 03:29 PM
zdriven28's Avatar
I actually do still have the stock drive shaft.
