Who has a Th350?
Who has a Th350?
Going PMed a guy about, have money in my hand just waiting for a adress to go get it.
Anyways, recently rebuilt with heavy duty clutch packs and a shift kit...what is needed for it to bolt up to a LT1?
I see the conversion for LS1s but not LT1s really...never looked into it
Dont really see why it wouldnt be streetable at all..
turbo 350 crossmember
stall
driveshaft
maybe a flywheel...but i doubt it
um...i saw somewhere bout a taill shaft for the 350 that has the correct hook up for your elec. speedo.
and i think thats it.
i just got a th350 also! gonna be doin this soon as well.
please chime in though if i missed something!!!
stall
driveshaft
I might be buying one tomarrow, just looking for what is all needed and were to buy it...also like you
Some people say its no good in a street car, but that makes no sense seeing how cars back in the day were driving around with them, juts a weekend car so its fine
i really do honestly wish i cold afford a nasty nasty 4l60e... but a build 350 is so cheap.. im gunna do a t-brake rev/manual valve body...
Redneck performance is probly who im going to try...
Transbrake valve body
Full manual shift
Reverse shift pattern
Heavy duty 36 element sprag & direct drum assy
Deep pan
High performance frictions
Rated to 700 HP
Dyno tested prior to shipment
6 month warranty
FREE 9.5" custom stalled TH350 converter with purchase of the transmission (anti balloon plates, fully furnace brazed, Torrington bearings)
Additional transmission upgrades available to purchase upon request
Shipping is a flat rate $130 to the US 48 continental states delivered to a business
US $1,150.00
Full manual shift
Deep pan
Rated to 700 HP
6 month warranty
US $1,150.00
If you build it right, it will hold up and go in without a hitch. You should have it built with a Tekpak-Fitzall switch kit. This will allow you to use your 4L60 tailshaft by using a 1 3/4" alluminum spacer. This allows you to use the stock crossmember, stock torque arm mount, stock length driveshaft, and stock speedo sensor. The kit comes with a spacer and hardware, and a longer output shaft. You have to put the output shaft in during a rebuild though.
Otherwise you would need a 9" tailshaft on your TH350 to allow use of the stock length driveshaft. But you would still need a modified crossmember.
a good way to see what you will be doing with no overdrive is to drive around in 3rd gear for a4 or 4th gear m6, keep in mind they are locked up, so if you go unlocked converter your rpms will be a little higher depending on stall
Originally Posted by 94Pontiac
3rd gear in the th350 is just 1.00, same as 4th in a m6 and 3rd in the 4l60e.
and lower numerical gears would definitly help streetability but will cost you a little at the track
Originally Posted by dhdenney
I would use a 3.08 gear for street. If I go 9" I'm going to use a 3.00 and if I do 12 bolt I'm gonna use 3.08. That way it'll be about 2500 at 65 mph.
So should I just leave in the 2.73?
Well you'll have the ultimate highway gear for a 3 speed auto. From what I have read, people with the A3 and the high gears are not really suffering any performance loss.
