Who has a Th350?
Old Apr 23, 2007 | 10:14 PM
slick1851's Avatar
Default Who has a Th350?
Going PMed a guy about, have money in my hand just waiting for a adress to go get it.
Anyways, recently rebuilt with heavy duty clutch packs and a shift kit...what is needed for it to bolt up to a LT1?
I see the conversion for LS1s but not LT1s really...never looked into it
Dont really see why it wouldnt be streetable at all..
Old Apr 23, 2007 | 10:50 PM
4thgenz's Avatar
turbo 350 crossmember
stall
driveshaft
maybe a flywheel...but i doubt it
um...i saw somewhere bout a taill shaft for the 350 that has the correct hook up for your elec. speedo.
and i think thats it.
i just got a th350 also! gonna be doin this soon as well.
please chime in though if i missed something!!!
Old Apr 23, 2007 | 11:03 PM
slick1851's Avatar
I might be buying one tomarrow, just looking for what is all needed and were to buy it...also like you
Old Apr 24, 2007 | 07:25 AM
slick1851's Avatar
Some people say its no good in a street car, but that makes no sense seeing how cars back in the day were driving around with them, juts a weekend car so its fine
Old Apr 24, 2007 | 07:29 AM
plaf713's Avatar
yuck, no over drive
Old Apr 24, 2007 | 09:54 AM
z28hustle's Avatar
Originally Posted by plaf713
yuck, no over drive
what tranny are you running on that stroker? and how much did you spend?
Old Apr 24, 2007 | 10:38 AM
plaf713's Avatar
1200 on a built 4l60e, relax guy its a joke
Old Apr 24, 2007 | 11:16 AM
Dragframe's Avatar
i really do honestly wish i cold afford a nasty nasty 4l60e... but a build 350 is so cheap.. im gunna do a t-brake rev/manual valve body...
Redneck performance is probly who im going to try...
Transbrake valve body
Full manual shift
Reverse shift pattern
Heavy duty 36 element sprag & direct drum assy
Deep pan
High performance frictions
Rated to 700 HP
Dyno tested prior to shipment
6 month warranty
FREE 9.5" custom stalled TH350 converter with purchase of the transmission (anti balloon plates, fully furnace brazed, Torrington bearings)
Additional transmission upgrades available to purchase upon request
Shipping is a flat rate $130 to the US 48 continental states delivered to a business
US $1,150.00
Old Apr 24, 2007 | 01:14 PM
BizZzatch350's Avatar
Moderator
The TH350 if the car isnt geared crazy is fine around town, fun to rip on, kinda sucks on the high way though. Also a lot have done the conversion on LT1s, more than you think. People were doing the conversions before the LS1s were out.
Old Apr 24, 2007 | 05:29 PM
smoknta's Avatar
If you build it right, it will hold up and go in without a hitch. You should have it built with a Tekpak-Fitzall switch kit. This will allow you to use your 4L60 tailshaft by using a 1 3/4" alluminum spacer. This allows you to use the stock crossmember, stock torque arm mount, stock length driveshaft, and stock speedo sensor. The kit comes with a spacer and hardware, and a longer output shaft. You have to put the output shaft in during a rebuild though.
Otherwise you would need a 9" tailshaft on your TH350 to allow use of the stock length driveshaft. But you would still need a modified crossmember.
Old Apr 24, 2007 | 05:50 PM
slick1851's Avatar
I mean it should be fine with a 3.73 gear and 65mph on the highway?
Dont really see a huge problem.....
Old Apr 24, 2007 | 06:15 PM
LT1Falcon's Avatar
a good way to see what you will be doing with no overdrive is to drive around in 3rd gear for a4 or 4th gear m6, keep in mind they are locked up, so if you go unlocked converter your rpms will be a little higher depending on stall
Old Apr 24, 2007 | 07:42 PM
slick1851's Avatar
So what do you suggest to go with? This is going to be a street car also...
slick1851's Avatar
Maybe get a 3.42 gear?
Old Apr 24, 2007 | 08:03 PM
94Pontiac's Avatar
3rd gear in the th350 is just 1.00, same as 4th in a m6 and 3rd in the 4l60e.
Old Apr 24, 2007 | 08:11 PM
LT1Falcon's Avatar
thats pretty much what i said.
and lower numerical gears would definitly help streetability but will cost you a little at the track
Old Apr 24, 2007 | 08:22 PM
Dragframe's Avatar
Well a th-350 tranny i should retain fair streetability because of me having a turbo car and longer gears (in the rear end).
Old Apr 24, 2007 | 08:38 PM
dhdenney's Avatar
I would use a 3.08 gear for street. If I go 9" I'm going to use a 3.00 and if I do 12 bolt I'm gonna use 3.08. That way it'll be about 2500 at 65 mph.
Old Apr 24, 2007 | 08:39 PM
slick1851's Avatar
So should I just leave in the 2.73?
Old Apr 24, 2007 | 08:43 PM
dhdenney's Avatar
Well you'll have the ultimate highway gear for a 3 speed auto. From what I have read, people with the A3 and the high gears are not really suffering any performance loss.
