MS4 on stock heads/flycutting?
Sorry if this is a newbie question, but can you run a MS4 cam on the stock 241 heads and not have to do any flycutting. Is there anyone running a set-up like this or no? What kind of power are you making? Also if no one is running this, why aren't too many people doing it, too big of a cam for the stock heads?
TSP says you should be okay, depending on the LSA, but I would measure it anyway just to be sure. Taking the time to measure everything is a lot easier and cheaper then bouncing a valve off a piston
not to hijack your thread or anything, but does anyone know what the ptvc readings are on stock heads and gasket? I have tried looking all over and can't find anyone that has actually measure it. I'm about to plug an ms4 into mine. If i can't find anyone that has i will post it up when i get mine in.
Originally Posted by red02Hawk
you should be fine on a cam only swap, people start pushing the limits when they mill the heads, get bigger valves and so forth. But the cam really does need a set of ported heads to show its true potential.
yeah the ms4 is fine on the stock heads... as long as you dont go under 111LSA then you should be fine. about porting the stock heads, i would look into a set of new ones b/c on a good porting job your looking close to around the same price so if thats the case spend a little more and get something better
Originally Posted by KrisXpc
Im on a 110 lsa... Still kicking...
Flycutting next month though just to be safe
How do you like the 110 lsa so far? The motor will be forged eventually..
What CC valve reliefs are you runing? Dyno numbers?
Thanks
Thanks
MS3 MS4 T-rex g5x4 etc etc come ALOT closer then the generally accepted amounts
call texas and they should be able to give you the actual measurements they've found
anybody else, i'm still wanting to know if anyone has actually measured and what they come up with!
