need help with lt1 water pump
i had a coolant leak, let the car cool off.i noticed that the hose that goes in the pointed area of picture had a leak..can anyone help me as to what hose this is and what it connects to.thanks
so when i call the auto parts store, i ask for a heater hose outlet? does anyone have a picture of the heater hose outlet? i see that it looks like a 3 piece part..hose that comes from firwall next to hvac connected to..aluminum connector connected to... another hose that connects to water pump (lower left side of pump, if youre looking at it from the front of the engine)
You didn't specify what year your car is, but here're the heater hose diagrams for all years of F-bodies. If the part of the hose that's leaking is the one labeled "#12," then the part number for it is 10188037 .
same prob kinda
can I order just the valve number 13 and how does it connect to those to lines because it looks like it is pressure crimpt on there...... OR can I just put a straight connector there and just connect them together without the valve?
Feel free to remove it, and just splice the two ends together with a barb and clamps. You'll never know it was gone.
Originally Posted by HIZPANICGUY21
THANKS..my car is a 97..ill need #13 and #12..should i cut off the aluminum looking cripmt thing..and just use 2 clamps..one on each side of the of #13?will that work just fine? thanks
#13 will work as a coupling right? hose + #13 + hose right? with the 2 clamps, one on each side of #13?
Obviously it'll work as a coupling, , I just can't guarantee whether it'll work with worm clamps. Why don't you try it and tell us what you find out?
