Moroso Cold Air Intake
Does anyone have the Moroso cold air intake on their LT1 with a vortech or trick flow elbow? I'm trying to install mine and to get everything hooked up with the MAF sensor looks like I have to cut about 1-2" off the end of the Moroso to get everything installed? Has anybody done this as well?
I hope its normal.
I hope its normal.
Originally Posted by TwoFast4Lv
Did you wind up with on for a 93?
Just checked and I ordered the 94-97 Moroso kit. I must be doing something wrong unless my Vortech elbow is alittle longer than stock? I'll try again after work.
I have the same set up u have. i had the exact same problem. all i did was turn the mass air flow sensor so the connector is on the side and plugged it up and now the hood closes with out a little bulge sticking into it. just turn it to the side and it works fine. never looked back since installing it.
