Changing 2-3 Shift Solenoid
Does anyone have any detailed instructions regarding changing the 2-3 shift solenoid.
I am in Iraq and my wife has the GTO getting some issues with the stall converter (going into limp mode due to the 2-3 shift solenoid even though it does have 3rd gear).
I want to send her some detailed instructions to hand off to the automotice shop on base so they can drain the fluid, change filter, and change solenoids.
Thanks.
I am also looking for a place online to buy the solenoids.
Thanks.
LS1Tech Sponsor
Yes thats happens often we have customers call with our new tranny and converter thinking they have a bad solenoid when they just need a tuning change, Its odd though some cars will throw the code and others will not with the same converter. 3000 up stall and you never know maybe it will maybe it wont
__________________
Originally Posted by performabuilt
They are very easy to replace , No more difficult than changing the filter, but again I think you may actually have a tuning issue not a solenoid issue
i'm recently having a problem wiht the solenoid too car was doing fine now it seems like it either stuck in 2nd and tries to hunt(rpms surge to about 3.5k then back down) cant get the car to go past like 20/30 mph, its stock tranny with performabuilt 4k verter
The P0756 code is defined as "Shift solenoid B - Performance or stuck off".
If the pan is off it won't hurt a thing to replace the two shift solenoids. It could easily be related to the high stall converter as well... but not likely IMHO.
But, based on the fluid condition and the symptoms I am going to stick with my comments about the 3/4 clutches being burnt.
If you would like to discuss it further don't hesitate to give me a call. I'll be in all day today.
g
g
