Mach 1 (n/a) vs Turbo LS1. Surprise!
Add few cubes, stir and eat a few LS1's. This takes care of all Mustangs needing a s/c debate, though they will rage on.
http://videos.streetfire.net/video/8...1c000f063c.htm
That stang runs pretty strong. Any dyno numbers or track times? Was there weight reduction in the video? Does it run on pump gas?
I was actually real surprised by that cobalt, it seemed to hang as well as the f-bodys.
Originally Posted by redz_02
This is going to be interesting. 32 valve 5.0 ltr's are pretty stout, maybe he should take on an LS1 stroker .
Originally Posted by Tan327
Yeah, it's a shame N/A LS1 cars can't move out like that.
Originally Posted by 1nastyss
I beg to differ....Theres been plenty of bolt on ls1's in the 11's, add a cam ,a good tune, tires ,and a good driver, u can be in the 10's.....not often but it has been done more than once
Badass Mach. Mad respect for going N/A with it and running that fast. (of course the gearing helped as well, and goddamn do those 32V love a short gear!!) How big are those Stage 3 cams, what range if you can't be specific?
Originally Posted by kennyxg
Can you post a vid of the Mach at idle? Want to hear the cams.
http://www.cardomain.com/id/azuremach1
I'm not impressed, a built motor and only running low 12's @ 112-113 for the first set of timeslips and then 116-117 for the second set of timeslips. Do I smell spray? My bolt-on crate ls6 runs 11.8 @ 119 on 18's. I think those ls cars need the driver mod, hell I ran almost 113 with the ls1 in it and bolt-ons.
"Power Adder:
NX GEN-X2 nitrous system
Bottle Warmer
MSD Window switch
15 lbs bottle
Fuel pressure safety switch
WOT Switch
S.H.O. 400 HP nozzle
125 wet shot (57/32 jets)"
