cut out vs true duals...
Old 04-29-2007, 09:27 PM
josh3111's Avatar
Default cut out vs true duals...
I am getting a cut out installed and getting my car tuned properly for the cut out. However, I was wondering what is faster a cut out or true duals?
Old 04-29-2007, 09:44 PM
porksoda's Avatar
What do you mean "what is faster"? I personally went cutout for the loudness and price compared to duals. But now that I have a cam I want duals!
Old 04-29-2007, 09:50 PM
96redcamaro's Avatar
TD's will make more power than a cut out.
Old 04-29-2007, 09:55 PM
wickedbluess's Avatar
I have the Texas speed TD's and i can feel a bigger difference with it, much more power than a cut out! I would go with TD'S if you got the money.
Old 04-29-2007, 09:58 PM
josh3111's Avatar
naa..I already have a nice cat back...I was just wondering what makes more HP, torque etc...The cut out is being put on now.
Old 04-29-2007, 10:05 PM
slick1851's Avatar
True Dauls will make more power when your running straight thru mufflers....
Radical setups, just need header dumps off the long tubes but thats drag/race car stuff...
TDs for the win, I felt a gain from going from a Open Y pipe, to dauls it was worth it
Old 04-29-2007, 10:59 PM
plaf713's Avatar
anyone running the texas speed true dual? is that made to go all the wawy back or dump before the axles? 459 seems pretty expensive if it dumps before the axles
Old 04-29-2007, 11:09 PM
97blackz28's Avatar
i am not sure but i would bet it dumps before the axle, as a custom over the axle set up can cost $1000+
Old 04-29-2007, 11:10 PM
slick1851's Avatar
TSP dumps pretty much at the axel....
Old 04-29-2007, 11:15 PM
plaf713's Avatar
thats why you go under the axles, but am i the only one that thinks that 459 is alittle to much? i bet you could peice one together cheaper
Old 04-30-2007, 10:21 AM
josh3111's Avatar
so then a cut out will make more power than a regular cat back right?
Old 04-30-2007, 02:32 PM
plaf713's Avatar
yes cut outs will but you will loose tow end torque with them
Old 04-30-2007, 02:56 PM
nomoneyz's Avatar
On my stock car with the cutout open I didnt lose any torque on the dyno. I had a 10hp and 1tq gain.
Old 04-30-2007, 02:58 PM
Captainofiron's Avatar
the flow of the exhaust out of a true duals system will be much more consistent and smoother than out of a cutout
Old 04-30-2007, 03:55 PM
plaf713's Avatar
never said you would loose hp, usually you low end torque drops a little and you gain it on the high end
Old 04-30-2007, 04:25 PM
josh3111's Avatar
10 HP at the rear wheels...that doesn't sound bad at all.!!
Old 04-30-2007, 04:54 PM
lt197formula's Avatar
Get a universal x pipe from Jegs or Summit if you want to save money. And having true duals run over the axle isn't that expensive, only cost me $240 without the price of the tips.
Old 04-30-2007, 05:00 PM
Mattybz28's Avatar
You don't need a tune to run a cut out.
Old 04-30-2007, 09:04 PM
nomoneyz's Avatar
Ya I wasnt even expecting that but its cool I love it.
Old 04-30-2007, 11:49 PM
josh3111's Avatar
I am tuning it for my hot cam and deleting 02's
Quick Reply: cut out vs true duals...
