Baer Decelarotors cracked!
Old 04-30-2007, 01:43 PM
camar0corey's Avatar
Default Baer Decelarotors cracked!
I'm not very pleased right now. I've got about 20k miles on my Baer Decelarotors. They are cracking. Everywhere! Not just out from the cross drilled holes, but everywhere. I'm highly disappointed for $300 rotors. I've never done anything retarded either, like slamming on my brakes through a deep puddle or something stupid like that either.
Anyone else have this issue? I'm really angry right about now.
I have the LS1 brake setup on my car also for the rest of my brake setup details.
Old 04-30-2007, 05:50 PM
BlackHawk T/A's Avatar
Over and over again we try to preach to people to stay away from the drilled rotors...
Anyway sorry to hear that. Looks like some Brembos are in your very near future.
Old 04-30-2007, 06:48 PM
Have a recommendation??
I am highly pissed, I wouldn't think this would be, I would expect it if the rotors came from Africa or something..... I'll probably never contemplate Baer products ever again.
Old 04-30-2007, 06:49 PM
SoCalZ28's Avatar
A good aftermarket torque arm will help to reduce nose dive during braking...
Old 04-30-2007, 06:58 PM
Wrong thread????? Or does this relate to why my rotors cracked?
I have a spohn adj T/A.
Old 04-30-2007, 08:17 PM
JamRWS6's Avatar
Slotted and/or drilled rotors are much more susceptible to cracking. It is possible to crack ANY rotor...I've cracked brembos using HPS pads. For the price though the Brembo blanks are hard to beat.
Old 04-30-2007, 08:31 PM
gyrene2003's Avatar
what sponsor sells em?
Old 04-30-2007, 09:35 PM
Well I'm mostly pissed that my stock rotors seemed to be fine when I pulled them off and they had over 125k on them. Then these well cost a lot IMO for rotors, and are basically useless.
Have a link for these Brembo rotors??
Old 04-30-2007, 10:44 PM
Copy & Paste Moderator
VIP1's Avatar
Many sponsors carry Brembo OEM blanks, including Sam Strano and Tire Rack.
Old 05-01-2007, 03:06 AM
revtime's Avatar
Believe it or not I have Autozone Aimco Extreme cross drilled and slotted rotors on the front of my car with about 40k on em. I was working for them at the time and got my discount.
Anyway, they are still looking great and have not cracked or anything. Of course I drive like a gramma most of the time.
I figured they wouldn't last long but if you pussyfoot em they last.
Old 05-01-2007, 05:51 AM
ZodiacZ28's Avatar
camar0corey any pics of the Baer. +1 for sam.
Old 05-01-2007, 10:01 AM
On the tree
Sneakyws6's Avatar
Have you called Baer and see what they say. I ahve them same rotors as well with no issues.
They do carry a 2 year warranty on them if I remember right.
Not to start a crap storm but preaching about blanks does not mean much. I ran all sorts of blanks on my Formula and warped everyone of them within 5000 miles. I am not a hard driver, dont race, dont drag, dont do much of anything. I went thru the calipers at first to make sure none of the slider pins were frozen and they all work fine.
I never could figure that out, my 89 Formula had 180,000 miles on it and nver had the issue with blanks like I did with mine.
I put 50,000 on the powerslots before they had a crank and I replaced them with the Baers and have about 5000 miles on them so far.
Old 05-01-2007, 07:52 PM
I'll try to get a hold of a camera tommarow.
Yeah calling Baer sounds like a good idea, see what they will tell me. Probably that I'm SOL.
Old 05-01-2007, 10:44 PM
PLucas's Avatar
Try the Autozone duralast rotors. I have about 5k miles on mine right now. That is 5k hard miles. I autox and drive very hard on the street. This is with hawk hps pads. They have seen multiple 130+mph hard stops and havent warped at all.
Old 05-01-2007, 11:07 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Damn...how hard were you on the brakes?
While I don't have the Decelarotors, I do have their Eradispeeds for the bling factor, and they have been great to me as far as not cracking. Then again, I drive like a grandma.
Old 05-01-2007, 11:13 PM
EXGTPMAN's Avatar
i have seen porsche rotors with cracks and i asked one of the techs and he said it is normal. they will have some cracks due to heating and cooling.
Old 05-02-2007, 04:58 PM
JamRWS6's Avatar
Given the same material a blank is less likely to crack like a slotted or drilled rotor...that is just physics.
Your 89 Formula also doesn't have near the clamping or braking power....its hard to crack something unless you have a braking system that is strong enough to do it.
Old 05-02-2007, 10:34 PM
On the tree
Sneakyws6's Avatar
I had a 89 Formula, I have a 01 Formula now.
I warped 2 factory sets of rotors, the ones the car came with and the ones the GM replaced them with at 2000 miles. Turned them at 7000 miles only to have them warped by 12,000. Replaced them at 17,000 with Powerstops on all four corners and never looked back.
I dont want to get into a pissing match on this subject because both sides seem to be very adamant about how they like blank or drilled.
I personally have had no issues with my drilled rotors. They have held up at the drags with no issues and handled several 140+ stops with no issues. The only reason I have the Bears now is because they dropped under min specs and had one crack on one of the front rotors.
If solid rotors were the best option then motorcycles would be using them, yet every sport bike I have owned uses drilled rotors. T ouse the comparison to race cars doesnt relaly work as they use alot better materials and or realistically unobtainable materials that most people cant afford to use on the street like the carbon rotors.
To each their own and I will say this is one of those areas that we will have to agree to disagree.
Old 05-03-2007, 12:35 AM
speed_demon24's Avatar
You think gradual stop from 120+ is the same as 20+ minutes on the road coarse? And bikes can get away with drilled rotors because they are 2500-3000lbs lighter than cars.
Old 05-03-2007, 11:30 PM
VIP1's Avatar
The problem there was the metallurgy of the factory rotors. The factory rotors are not that warp resistant. The reason the second set warped sooner after they were turned is because turning them removed material which makes them more prone to warping.
Check out this sticky:
https://ls1tech.com/forums/showpost....91&postcount=5
Quick Reply: Baer Decelarotors cracked!
